Author Topic: What's the Likelihood!  (Read 2881 times)
June 16, 2009, 05:09:44 am
Mozza
  • 81
« on: June 16, 2009, 05:09:44 am »
Ok so i have been taking the engine to bits to change the water pipe and have found that there is a hose, to a pump, that then goes to the back of the engine which appears to go to the turbo. I have lots of oil in the water and have changed the oil cooler. ( not given it a propper run to see weather this has fixed our problem) If this does not fix it what are the chances that it will be oil and water mixing in the turbo somehow rather than the head gasket!
and how much am i lookin at for a replacement turbo :-\
Cheers for all your help,
Mozza
Reply #1June 16, 2009, 03:30:31 pm
hamradio
  • 282
Re: What's the Likelihood!
« Reply #1 on: June 16, 2009, 03:30:31 pm »
I highly doubt that your watecooled turbo somehow cracked and is allowing coolant and oil to mix.
Reply #2June 16, 2009, 04:23:03 pm
Rabbit TD
  • 840
« Reply #2 on: June 16, 2009, 04:23:03 pm »
By chance do you have any water in the oil also?  Normaly with the bad headgaskets you don't get water in the oil but there is usualy a little oil in the water in the reservoir but with all the headgaskets I've had go bad on 1.6's I've never had any water get into the oil.  I bet you already fixed it with the new cooler.
Reply #3June 16, 2009, 05:06:37 pm
« Reply #3 on: June 16, 2009, 05:06:37 pm »
i've had an oil cooler go on me.  it makes some weird stuff happen.  i thought my engine was dying  ;D  flush the coolant and hope for the best!
Reply #4June 17, 2009, 01:34:50 am
Mozza
  • 81
« Reply #4 on: June 17, 2009, 01:34:50 am »
W drained the oil twice now and dont seem to have water in the oil, so am hoping to god i fixed it with the oil cooler so rare for the turbo for this to be causing the problem,
Reply #5June 17, 2009, 08:19:08 am
Mozza
  • 81
« Reply #5 on: June 17, 2009, 08:19:08 am »
Ok right Got some coolant flush stuff and will have a go at that tonight and se over the next day or two of the problem has been fixed but if not Is the Any reason for me to worry about something gone wrong in the turbo to cause the oil in the water problem, as my dad, because of what some tit has told him, believes it will be the turbo and want to put his mind at rest that it may just be the head gasket if it is not the oil cooler,
Reply #6June 17, 2009, 09:21:15 am
92EcoDiesel Jetta
« Reply #6 on: June 17, 2009, 09:21:15 am »
I wouldn't drop the turbo in a bucket of water and so would want to add the shrader valve and a gauge.  If the pressure drops then you have a leak.  If not, then change the head gasket and flush the cooling system.
You can drop the turbo in a bucket of diesel though.
Reply #7June 17, 2009, 12:40:04 pm
Mozza
  • 81
« Reply #7 on: June 17, 2009, 12:40:04 pm »
Cheers guys Im so sorry to be a pain in a behind but I have never had a diesel, turbo or fuel injection car before so a lot of this is new to me, we have just changed the oil cooler and had to change the main water pipe as-well and now need to flush the system out as the amount of gungy oil that was in the pipes was incredible, we were horrified to be honest so will se if this fixes the problem and then on to the head gasket if not!
Once again Thank you for your help and it is a pleasure to be pert os such a knowledgeable forum,
Mozza
