Author Topic: fill hole for 5 spd?  (Read 3054 times)
June 14, 2009, 01:20:29 pm
92EcoDiesel Jetta
« on: June 14, 2009, 01:20:29 pm »
I see where the drain plug is, but until I know where the fill is, I'm not draining it. Below where the arrow points there's a big plug (hex drive) but a cable is in front of it.
What's that big Hex looks like 27 mm (big circle)?
Is the small circle the speedo cable?
Got an email on Fri that my Bently has been shipped so I won't be asking thse dumb questions anymore
Reply #1June 14, 2009, 01:57:03 pm
rallydiesel
  • 1880
Re: fill hole for 5 spd?
« Reply #1 on: June 14, 2009, 01:57:03 pm »
There's a hex plug on the driver side wheel of the tranny. That's the one you fill to the bottom of. Obviously, you'll need to take the wheel off and use a long funnel to top off the tranny fluid. Hex plug is 17mm. Same as a lug nut if you can't find a large enough hex key.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2June 14, 2009, 02:06:44 pm
hamradio
  • 282
« Reply #2 on: June 14, 2009, 02:06:44 pm »
The big circled one is the selector shaft detent bolt.  Small circle is indeed your speedometer cable.
Just fill it through the speedo cable hole with a funnel with a hose on it.
« Last Edit: June 14, 2009, 02:08:18 pm by hamradio »
Reply #3June 14, 2009, 02:21:01 pm
92EcoDiesel Jetta
« Reply #3 on: June 14, 2009, 02:21:01 pm »
Speedo hole looks easier. Just remove the bolt and lift the speedo cable and the plate off? I have a qt. of Redline MTL. Is that compatible? If the old fluid is real dirty, I'd want to flush it first. What do I use to flush with? engine oi or 90W gear oil? It takes 4.2 pints is that right?
Reply #4June 14, 2009, 02:23:16 pm
macka
  • 957
« Reply #4 on: June 14, 2009, 02:23:16 pm »
BIg funnel? CT sells a tranny fill cap that goes right on the bottle. I feed the tube into the fill hole, and then turn the bottle over, open the valve and let it flow in. Sometimes I heat the bottle in hot water to make it flow faster.
Quote from: Vincent Walden
Reply #5June 14, 2009, 03:51:52 pm
« Reply #5 on: June 14, 2009, 03:51:52 pm »
www.brokevw.com... pictures, capacities, everything anyone needs to know about the 020 tranny.
Reply #6June 14, 2009, 08:13:20 pm
92EcoDiesel Jetta
« Reply #6 on: June 14, 2009, 08:13:20 pm »
Thanks! Very helpul site!
Reply #7June 15, 2009, 10:54:03 am
92EcoDiesel Jetta
« Reply #7 on: June 15, 2009, 10:54:03 am »
How about removing the bolt first and make sure nothing else around can fall in before lifting the cover?
