Author Topic: starting problems  (Read 2985 times)
June 10, 2009, 02:02:47 am
Zulfiqar
  • 254
starting problems
« on: June 10, 2009, 02:02:47 am »
Hi
I was rebuilding a 1.6 NA motor - and then had a little incident in which I couldnt complete it myself, my friend called in a mechanic fitter to assemble the engine - it seems that he has assembled it correctly with the timing ok and all - but when we try to start it - unburnt diesel is pumping out of the blow pipe on the valve cover - any ideas on what this could be - first it was trying to catch but now the engine is too heavy to turn over - let alone start..
the motor has new rings - new valves, guides, and everything - never had a prob like this after a rebuild
Diesel IS the future
Reply #1June 10, 2009, 02:53:22 am
Golf/Jetta
  • 102
Re: starting problems
« Reply #1 on: June 10, 2009, 02:53:22 am »
heavy to turn over... by hand or starter?
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
Reply #2June 10, 2009, 03:18:39 am
Zulfiqar
  • 254
« Reply #2 on: June 10, 2009, 03:18:39 am »
by starter and hand both
what is puzzling is that the blowby smells of unburnt diesel - and Im getting no smoke at the tailpipe - just puffs of air pressure
Reply #3June 10, 2009, 04:56:27 am
arb
« Reply #3 on: June 10, 2009, 04:56:27 am »
How are you turning it over by hand ? With a socket and rench on the crank pulley ? How many ft-lb does it take? Until you get all the injectors primed, its not going to want to run and you'll get unburned fuel. Very strange its in the valve cover.
Reply #4June 10, 2009, 06:09:34 am
Zulfiqar
  • 254
« Reply #4 on: June 10, 2009, 06:09:34 am »
by heavy you can say its normal for a tight diesel - like you are trying to spin a good diesel with a 19mm combination wrench on the crank pulley.
Ive retarded the pump timing a bit as it was not put on by a dial gauge, its not puffing out now - just heavy on the starter - my gauge got nicked when I gave it to a machinist for making a copy of my adapter..
Reply #5June 10, 2009, 09:34:50 am
arb
« Reply #5 on: June 10, 2009, 09:34:50 am »
I hope its not the same machinist who put your engine together for you ;-)
Reply #6June 10, 2009, 10:45:36 am
Zulfiqar
  • 254
« Reply #6 on: June 10, 2009, 10:45:36 am »
that machinist has closed business for reasons I dont know - I made myself another adapter from the little bench lathe I have.
Anyway - I retarded the pump timing about 1 pencil line - and it does start now after towing, it gives no smoke at all no black, no white, no nothing, the blow pipe is chuffing out light pulses of air - BUT its running on only 3 cylinders the 4th injection nozzle is not working...
 >:( I cant work on it at the moment and Im starting to hate it
Reply #7June 10, 2009, 11:32:36 am
Golf/Jetta
  • 102
« Reply #7 on: June 10, 2009, 11:32:36 am »
i wonder if the cam and crank where over tightend
Reply #8June 12, 2009, 12:46:21 pm
Zulfiqar
  • 254
« Reply #8 on: June 12, 2009, 12:46:21 pm »
a little better development - the 4th nozzle was not working proper - serviced it and is spraying nice now, all that comes to mind now is to remove cam and take out lifters - empty them and install them back - because its not able to idle properly
Reply #9June 12, 2009, 02:17:14 pm
« Reply #9 on: June 12, 2009, 02:17:14 pm »
Could the little return line off the fourth injector be plugged into the vacuum pump? I've heard of it being done, check the oil.
