General Information
Troubleshooting
injection pump
Topic: injection pump (Read 4872 times)
June 09, 2009, 08:14:04 pm
dave friday
injection pump
June 09, 2009, 08:14:04 pm »
hi all,anyone know what causes the engine revs to go up and down [just above idle 1000/1200 rpm].
ta.
1992 1600 td syncro camper
June 09, 2009, 11:20:11 pm
Re: injection pump
June 09, 2009, 11:20:11 pm »
Make sure all the IP mounting bolts are tight and that the brackets aren't cracked.
June 10, 2009, 03:05:30 am
dave friday
Re: injection pump
June 10, 2009, 03:05:30 am »
thanks for that,the fixings are all ok,it could be a mis-fire as the engine shakes a bit [i know of two other vans with the same problem!], my knowledge of injection pumps is a bit limited,could it be sucking air at those revs? [ i p drive shaft has a bit of radial play ].
June 10, 2009, 12:53:31 pm
Re: injection pump
June 10, 2009, 12:53:31 pm »
Yes, air can cause missing.
A clear fuel hose feeding the IP would let you see if there's bubbles.
June 11, 2009, 09:13:30 am
airhead
Re: injection pump
June 11, 2009, 09:13:30 am »
Mine does this a little bit too when its warming up but seems to stop once it gets up to operating temperature. I dont worry about it.
June 11, 2009, 03:24:56 pm
Rabbit TD
Re: injection pump
June 11, 2009, 03:24:56 pm »
Quote from: rabbitman on June 10, 2009, 12:53:31 pm
Where in the world does a person get that clear hose at anyway. Tractor Supply has some that says "Chemical Reistant" and I've been tempted to try it, what does anybody think about this?
June 12, 2009, 05:24:59 am
BlastIt
Re: injection pump
June 12, 2009, 05:24:59 am »
Auto parts store can get it for you. Some carry it in stock. Just tell them you need clear fuel line. They should
be able to hook you up.
General Information
Troubleshooting
injection pump
