Author Topic: Question about headgasket  (Read 2454 times)
September 07, 2005, 02:13:33 pm
entuzijast
  • 73
    • http://www.geof.hr/~imalovic
« on: September 07, 2005, 02:13:33 pm »
I have read all the posts, and i still dont have an answer..I have an IC, I have a real TD pump (I own eco Golf), but the only thing I don't get is the 1.9 TD head gasket..I am no mechanic, but how do you put a head gasket with bore 79.5mm on a engine with bore 76.5mm?
Or you are talking about some another 1.9 L engine?
Excuse me on my bad English
Reply #1September 07, 2005, 03:28:15 pm
vwmike
  • 1158
Re: Question about headgasket
« Reply #1 on: September 07, 2005, 03:28:15 pm »
Quote from: "entuzijast"
The gasket bore is just larger but it will still seal as the dimensions of the block surface are still the same. This will also lower the compression a bit.
Reply #2September 07, 2005, 03:35:51 pm
entuzijast
  • 73
« Reply #2 on: September 07, 2005, 03:35:51 pm »
Lower the compression?..How much?..What I mean, in winter can be very cold, and compression is significant for cold start...
