Author Topic: WTB: crankshaft timing belt sprocket and pulley 96 jetta AAZ  (Read 5099 times)
September 06, 2005, 10:17:01 pm
insdtanoodles
  • 148
« on: September 06, 2005, 10:17:01 pm »
the sprocket is much more important to get because there is damage on the inside of the sprocket that prevents it from sitting flat against the crankshaft. Since it wobbles while spinning the back of the harominic balancer has been all scored up and the rubber ring is starting to creep out of its slot. Looking for the part around the GTA but will drive around ontario for the parts if need be, thanks.
1996 vw jetta AAZ
Reply #1September 07, 2005, 06:13:29 am
QuickTD
  • 1156
« Reply #1 on: September 07, 2005, 06:13:29 am »
The crank timing sprocket is only $30-40 new at frisco auto parts, make sure to get a new bolt as well.
 The harmonic balancer is the same on the 96-99 TDI as well. You might have better luck finding a TDI in the wrecking yard.
Reply #2September 07, 2005, 06:18:56 am
RedRotors
  • 734
    • http://www.mikrotuning.com
« Reply #2 on: September 07, 2005, 06:18:56 am »
Where are you locates Instan ? I have a AHU TDI crack with sprocket if you are interested..
Marc/
PS: Please fill your location ID.
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
Reply #3September 07, 2005, 09:32:54 am
insdtanoodles
  • 148
« Reply #3 on: September 07, 2005, 09:32:54 am »
I will have to go to frisco's today and I found a harmonic balancer for 200 bucks, much better then 600 at volkswagen. I also dont think I need a whole crankshaft, wouldnt know how to install it but thanks for the offer. I also updated my location, I live in scarborough ont.
1996 vw jetta AAZ
Reply #4September 07, 2005, 04:40:56 pm
fspGTD
  • 1529
« Reply #4 on: September 07, 2005, 04:40:56 pm »
This place has the VW Diesel serpentine belt style harmonic balancer available for only $65 (US)!  Check it out:
http://www.autohausaz.com/catalog/lookup_parts.cfm?PartNum=028105243T
Note: also this part number is the "updated" style ('97 and onwards)
Jake Russell
Reply #5September 07, 2005, 08:49:21 pm
insdtanoodles
  • 148
« Reply #5 on: September 07, 2005, 08:49:21 pm »
thanks for the link on the harmonic balancer and friscos didnt have the timing belt sprocket at any of their stores but it is only 60 dollars at the VW dealer with the new bolt so I think I will just get that. Is there any garages in the gta that specialize in vw diesel's? Once I get those 2 parts installed, I need to get my injection pump timed and my injectors tested/replaced and I cant do that myslef, I dont have to tools. Once all that is done then to car is almost perfect, just gotta fix that transmission whine.
Thanks
1996 vw jetta AAZ
Reply #6September 08, 2005, 06:02:08 am
QuickTD
  • 1156
« Reply #6 on: September 08, 2005, 06:02:08 am »
I bought a pulley at frisco in missisauga about 6 months ago, strange they don't stock it anymore. I must have got the last one...
 That harmonic balancer is a bargain at twice the price though. Would be easily worth the 50 bucks in brokerage fees to have it shipped.
