Author Topic: air bubbles  (Read 3256 times)
June 03, 2009, 07:58:13 am
juleshs
  • 49
air bubbles
« on: June 03, 2009, 07:58:13 am »
i keep geetting a lot of air bubbles in my fuel lines, as this a bad thing?
also if my fuel pump is not timed properly will it be noisy?  aaz
Reply #1June 03, 2009, 10:26:27 am
96jetta
Re: air bubbles
« Reply #1 on: June 03, 2009, 10:26:27 am »
did you replace the fuel filter?
Reply #2June 03, 2009, 10:30:57 am
juleshs
  • 49
Re: air bubbles
« Reply #2 on: June 03, 2009, 10:30:57 am »
yes new filter
Reply #3June 03, 2009, 10:33:44 am
96jetta
Re: air bubbles
« Reply #3 on: June 03, 2009, 10:33:44 am »
how bad is the mix between fuel and air?
Reply #4June 03, 2009, 10:47:02 am
juleshs
  • 49
Re: air bubbles
« Reply #4 on: June 03, 2009, 10:47:02 am »
if by mix you mean how many bubbles, well since i have been building this car (about 4 years) it as mostly been sat ticking over i took it to the mot station about 5 mile round trip. there have always been a lot of bubbles, in the clear pipe between the filter and the pump there is always some bubbles there but doesnt seem to effect the perfomance
Reply #5June 03, 2009, 02:44:28 pm
Re: air bubbles
« Reply #5 on: June 03, 2009, 02:44:28 pm »
Bubbles will with out a doubt cause performance issues. If the engine thinks its getting X amount of fuel from the pump according to the RPM of the engine, and its really getting 70%X (fuel) and 30%Y (air) it is going to hinder performance substantially. Say the engine is spinning at 1800 and is receiving the appropriate fueling to do so.. now you add air in to the fuel and it is only getting enough fuel for 1500 rpm.. You will push the peddle more but you will get less power. It's just a bad thing, lol.
Check all your fuel lines. Did it have air bubbles before replacing the filter? check those connections especially. Add a clear line before the filter so you can see if it is coming from the filter or from the filter to tank section.
Reply #6June 06, 2009, 08:18:06 am
Golf/Jetta
  • 102
Re: air bubbles
« Reply #6 on: June 06, 2009, 08:18:06 am »
my AAZ does this. replaced all fuel lines/rubbers and still have the problem today..
are they big bubbles or tinny..
tinny bad
big OKż
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
Reply #7June 06, 2009, 08:27:42 am
Re: air bubbles
« Reply #7 on: June 06, 2009, 08:27:42 am »
tinny bad
big OKż
What?  :o
ANY BUBBLES are bad  ;D There should be no bubbles whatsoever in the fuel system. You have a leak somewhere, it is advised that you fix said leak :)
Reply #8June 06, 2009, 08:28:59 am
Re: air bubbles
« Reply #8 on: June 06, 2009, 08:28:59 am »
There should NEVER be any air in the fuel entering the engine.  The amount that is O.K. is NONE.
Beat ya to it Andrew  :D
Reply #9June 06, 2009, 02:38:42 pm
veedubcanuck
  • 151
Re: air bubbles
« Reply #9 on: June 06, 2009, 02:38:42 pm »
My 93 does the same. I see the odd bubble (one every maybe 8 sec.) Done it since day 1 when the car was new. Never had an issue.
Reply #10June 06, 2009, 02:39:57 pm
Re: air bubbles
« Reply #10 on: June 06, 2009, 02:39:57 pm »
That is an issue. Feed or Return line?
Reply #11June 06, 2009, 03:40:17 pm
ezekiel
  • 147
Re: air bubbles
« Reply #11 on: June 06, 2009, 03:40:17 pm »
Truth.
You all need to replace your copper crush washers, most likely.
Reply #12June 06, 2009, 04:06:07 pm
Re: air bubbles
« Reply #12 on: June 06, 2009, 04:06:07 pm »
O-ring at the return tee on the fuel filter is another common suspect, for those vehicles so equipped.
Reply #13June 06, 2009, 04:16:20 pm
macka
  • 957
Re: air bubbles
« Reply #13 on: June 06, 2009, 04:16:20 pm »
when I got my car it was a beast to start because there wasn't an O ring in the tee.
Quote from: Vincent Walden
