Author Topic: Tach question  (Read 5784 times)
Reply #15June 03, 2009, 06:01:43 am
fairweather
  • 85
    • TDI Syncro
Re: Tach question
« Reply #15 on: June 03, 2009, 06:01:43 am »
Here's alink to some pics in the TDIvanagon group for the wiring of the Alt with no "w" spot.
http://groups.yahoo.com/group/TDI-conversion/photos/album/706123428/pic/list
TV
83 Caddy with CY code 1.6TD out of a rabbit.
Reply #16June 04, 2009, 05:15:59 pm
allsierra123
Re: Tach question
« Reply #16 on: June 04, 2009, 05:15:59 pm »
Any one ever thought of using a Gasser alternator with a tach wire on it?
Reply #17June 04, 2009, 10:05:28 pm
Re: Tach question
« Reply #17 on: June 04, 2009, 10:05:28 pm »
From the tach's perspective that should work just fine.
From rest of the car's perspective.... the gasser alternator is usually significantly smaller (ie 65A on an MK2 iirc) vs the beefier diesel version (90A, again iirc) which means it may struggle a bit to charge a cold battery while running the defrost fan, rear window defogger, and headlights.  MC Hammer thumping on the stereo won't help either. :o
Once again, I'd say it all comes down to the immortal words of Clint Eastwood:
Do you feel lucky, punk?  Well, do ya?
If you live in a warm climate where your battery is always in a good state of charge and you don't need your glowplugs much you're probably in ok shape.  In Edmonton there's mornings I'd like 120 Amps... all of them channeled towards the heated seats.  ;)
Reply #18June 05, 2009, 05:40:43 am
allsierra123
Re: Tach question
« Reply #18 on: June 05, 2009, 05:40:43 am »
So its that simple basicly? just find a 2.0 gasser alternator and hook to my and away I go.
Reply #19June 05, 2009, 10:10:45 am
92EcoDiesel Jetta
Re: Tach question
« Reply #19 on: June 05, 2009, 10:10:45 am »
Are there any VW diesel models that does NOT use a signal from the alternator's W terminal? Most diesel tachs I've seen (on other makes) use a magnetic coil pickup on a tooth off of the crankshaft or flywheel.
