Author Topic: Cooling fans  (Read 3352 times)
May 27, 2009, 05:44:59 pm
92-Eco
Cooling fans
« on: May 27, 2009, 05:44:59 pm »
hello everyone,
New guy here, just picked up a red 92 eco diesel jetta. I had a few questions, The water neck on the front side of the head has 2 electrical connections (found it in the trunk). My car has a neck with only 1 connection that will not hook up to the factory connections, so niether is hooked up. Ive been messing with the 2 factory connectors coming from the wiring harness and found that one is for the glow plugs and the other is for the temp guage. I was wondering if there is any place that sells these water necks? Also i found the temp sensor on the bottom of the radiator that turns the fans on, I was wondering how often these fans usually come on? I tested the fans, they work great both speeds, just havent had a chance to test the sensor yet.
