Author Topic: Transmission Removal Questions  (Read 2489 times)
May 26, 2009, 10:19:29 pm
Matteo
  • 47
« on: May 26, 2009, 10:19:29 pm »
Hi volks,
I pulled an engine and trans out of an 87 and want to put the AGS trans into the 90 jetta.
I have removed the two large top bolts, 19mm I think. Also one bolt for the starter.
However, there are two more bolts holding the starter on and they have a start like pattern.
Can anyone tell me the size? Thanks,
Matt
Aircooled rules!
Biodiesel makes us better humans.
Make your own fuel and stick it to the man!
I never thought it was possible to Love a car.
Help me I'm sick!
Reply #1May 26, 2009, 11:29:39 pm
maxfax
  • 2126
Re: Transmission Removal Questions
« Reply #1 on: May 26, 2009, 11:29:39 pm »
If they're not an 8mm allen head they are probably 10mm? tripple squares..
Reply #2May 27, 2009, 10:11:06 am
« Reply #2 on: May 27, 2009, 10:11:06 am »
there 8mm allen. i just use a torx bit that fits good in them. plus it has just enough wobble room that the tool clears the starter. dont forget the big long bolt on the back of the enigne that goes through the engine block into the tranny.
Reply #3May 27, 2009, 11:43:35 am
maxfax
  • 2126
« Reply #3 on: May 27, 2009, 11:43:35 am »
8mm allen = 5/16" allen         I had one of these with tripple square bolts in the starter...  Of course it also had one of those mini starters of a late model gasser too.. ???
Reply #4May 27, 2009, 07:49:36 pm
« Reply #4 on: May 27, 2009, 07:49:36 pm »
it had a gas starter? how did it start? i had a gas starter in my well worn 1.6 TD engine and it would barely start that. i know there is no way i could get a gas starter to get my 1.5 fired. the gas starters are .7 hp. the diesel ones are 2.1 hp.
Reply #5May 28, 2009, 10:24:54 am
maxfax
  • 2126
« Reply #5 on: May 28, 2009, 10:24:54 am »
This was one of the little gear reduction high torque buggers like found on the MK3 gassers I think..  It actually started it fine other than it cranked a bit slow when hot..   I don;t know how long the PO had it on the car, but it didn;t last too long for me...
Reply #6May 28, 2009, 11:50:35 am
« Reply #6 on: May 28, 2009, 11:50:35 am »
haha. i didnt figure it would. when i had the gasser starter in there, it would start fine warm, but cold starting, you might as well be pissing up a rope.
Reply #7May 28, 2009, 12:43:26 pm
maxfax
  • 2126
« Reply #7 on: May 28, 2009, 12:43:26 pm »
I would have expected the same results..  Oddly enough it started fine when cold..  Even down around freezing..  When hot though it cranked hella slow.. Coulda been cables too though..  I replaced them when I put the proper starter on..
I gotta say though, when the gear reduction exploded in that gasser starter it made a nifty noise..
Reply #8May 28, 2009, 12:45:44 pm
« Reply #8 on: May 28, 2009, 12:45:44 pm »
LOL...
i bet it did make a funny noise.
