Author Topic: Can you help me find the Hockey Puck  (Read 6304 times)
May 24, 2009, 09:10:55 am
« on: May 24, 2009, 09:10:55 am »
I need one of the hockey puck things on the valve cover of a turbo that isn't on the N/A. I checked the vendors section, ebay, and asked around a little. I don't know what they are called that is part of the problem, but I think the function is to separate oil from oil vapors and let them enter into the intake. I have seen them in many pics in here and need to have one. Please let me know what it is and where I can get one. Thanks Lucas ><>
Reply #1May 24, 2009, 09:14:24 am
rallydiesel
  • 1880
Re: Can you help me find the Hockey Puck
« Reply #1 on: May 24, 2009, 09:14:24 am »
You're right, it's a baffle that coalesces the oil vapour so it pours back down into the head. You may want to post this in the "for sale" section.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2May 24, 2009, 10:43:43 am
« Reply #2 on: May 24, 2009, 10:43:43 am »
Yeah now thinking about it maybe the general section since I am not really buying/selling anything, just looking. Still need to know what it is.
Reply #3May 24, 2009, 02:39:48 pm
ezekiel
  • 147
« Reply #3 on: May 24, 2009, 02:39:48 pm »
racor makes a vapor seperator if you can't find a stock one.
Reply #4May 24, 2009, 02:41:08 pm
« Reply #4 on: May 24, 2009, 02:41:08 pm »
i got one, its painted white tho.
Reply #5May 24, 2009, 02:41:54 pm
stewardc
« Reply #5 on: May 24, 2009, 02:41:54 pm »
I have a stock one for a 1.6 and a 1.9. I also have a billet aluminum one (sorry, but that one's going on my engine).
Reply #6May 24, 2009, 03:02:45 pm
« Reply #6 on: May 24, 2009, 03:02:45 pm »
where can i find a billet one? i already have a billet oil breather catch can, but i built that myself.
Reply #7May 24, 2009, 03:43:35 pm
Jettagli16v
  • 344
« Reply #7 on: May 24, 2009, 03:43:35 pm »
The name you seek is:
"PCV Valve"
(ala, Positive crankcase ventilation)
Having a bit of a hard time finding one right away online to fit 85 golf,
I bought a new one from the dealer for $100 once,
but heres one for a mk3:
http://www.parts4vws.com/catalog/product_detail.asp?PartNumber=037129101R
This one has one bottom hole (to valve cover) and two upper outlets.
Cap the lower one and use the upper one and you are good to go!
You can go to an auto parts store, but it will be a cheap chinese piece of crap,
a good import specific parts store should be able to get one.
-Brad
Reply #8May 24, 2009, 04:14:44 pm
« Reply #8 on: May 24, 2009, 04:14:44 pm »
I should have known. All it is is a PCV? Could I use one from one like my 79 Ford Bronco? If that is all it is I don't see why not, unless it is as I figured and it was something special dreamed up from VW engineers. I wish I had a stock one to compare the vapor comming out. If someone wants to test I would appreciate it. Even if it has a little different results I don't think it could be that destructive could it? I am already using a different valve cover so unless it is some special engineered part I may give it a try as I am not spending 65-100 dollars on a PCV if I don't absolutely have to.
Reply #9May 24, 2009, 04:21:10 pm
Jettagli16v
  • 344
« Reply #9 on: May 24, 2009, 04:21:10 pm »
Nothing special at all,
standard PCV, and any will do.
(aside from logistical concerns with mounting)
You can dump into a catch can...
I did it for a week, cause I was concerned with the gook
going right into my turbo.
I quickly became more concerned with the gook & smoke
floating out from under my hood at every stop light.
Looked like the car was on fire,
stained everything in the vicinity,
and I was not a fan.
Back into the intake with the gook.
Sorry, turbo.
-Brad
Reply #10May 24, 2009, 04:42:36 pm
« Reply #10 on: May 24, 2009, 04:42:36 pm »
its not a PCV... theres nothing inside to limit the amount of air going through it like a PCV has. it has some separators and stuff in there. its supposed to trap oil vapor and drain it back into the engine. kinda an important part. the one on my engine is off of a gasser, valve cover and all.
« Last Edit: May 25, 2009, 08:40:25 am by Rabbit on Roids »
Reply #11May 24, 2009, 08:02:27 pm
« Reply #11 on: May 24, 2009, 08:02:27 pm »
Well then would a PCV work? I have always heard that you are supposed to vent it to the intake so that the oil mist lubes the valve guides/stuff. I am just looking for something to hook it up so I have something to do that. I have a little while yet to go for it, but I am trying to be prepared. I never had anything like it on the N/As I owned and didn't know if it was something special for the turbo models. I could build something out of a fitting and some screen if that is all it would take, or hollow out the PCV and put something in it to help keep most the oil down. Should turn this into a poll of what to do.
Reply #12May 24, 2009, 10:08:31 pm
Dakotakid
  • 1240
« Reply #12 on: May 24, 2009, 10:08:31 pm »
I'll get him a pucking puck!!!!
Got ya covered, Lucas.
Reply #13May 25, 2009, 05:58:15 am
« Reply #13 on: May 25, 2009, 05:58:15 am »
Thanks for the puck...now I am curious. Do these things come apart? What do they look like on the inside. I am interested in seeing one now and knowing how they work. Anyone have a pic of this thing apart?
Reply #14May 25, 2009, 08:16:45 am
Jettagli16v
  • 344
« Reply #14 on: May 25, 2009, 08:16:45 am »
well then,
I always defer to Andrew,
and am now wondering what detriment I caused to my '88 golf
running it for those years with a PCV from Discount jammed in the top of my valve cover!
-Brad
