Author Topic: Heats Up Fast !!!  (Read 2206 times)
May 24, 2009, 07:33:15 am
Golf/Jetta
  • 102
Heats Up Fast !!!
« on: May 24, 2009, 07:33:15 am »
Picked up another car (engine) over the week. AAZ
Boy O Boy this this can produce some heat Fast. Faster then my car. which is odd to me..
this car had some funky WVO + gas/Kerosene + some wax looking bubbles.
replace the fuel (regular diesel) with nill effect.
the engine was tuned way up. smoke screw, idle screw. but i tuned it down.
coolant doesn't overheat nor spill of of the reservoir, top rad hose gets somewhat stiff but not hard (norm i guess), bottom rad hose gets hot.. rad fan comes on.
theres some kinda rad leak stop in the over flow, sitting in there.
after turn it down, it still gets hot fast.. weird i never had a car (engine) that heats up this fast where the rad fan just stays on.
one notch head gasket, T3 turbo
thoughts?
« Last Edit: May 24, 2009, 07:36:43 am by Golf/Jetta »
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
Reply #1May 24, 2009, 07:56:44 am
farkman
  • 172
Re: Heats Up Fast !!!
« Reply #1 on: May 24, 2009, 07:56:44 am »
Maybe the injection timing is too advanced????
Reply #2May 24, 2009, 08:01:26 am
  • 1739
« Reply #2 on: May 24, 2009, 08:01:26 am »
Timing too advanced[like farkman says], but my money is on the stop leak. I have never seen good things result from using that stuff. Worked on a couple of cars which had to have both rads replaced and the rest flushed out like crazy to remove every last bit of it to fix the overheating and no interior heat problems.
Reply #3May 24, 2009, 08:31:19 am
53 willys
« Reply #3 on: May 24, 2009, 08:31:19 am »
thoughts?
flush the system first thing....radiator stop leak is the devil!!!!
Reply #4May 24, 2009, 02:51:52 pm
« Reply #4 on: May 24, 2009, 02:51:52 pm »
those bottles they sell you, theres enough in those bad boys to fix a big rigs radiator that you just drove a ford fiesta through.
