Author Topic: A/C Removal  (Read 4136 times)
May 23, 2009, 08:19:59 pm
mystery3
  • 774
A/C Removal
« on: May 23, 2009, 08:19:59 pm »
Would here be any ill-effects from pulling everything a/c related, capping the oulets of the compressor and using the compressor solely as a tensioner? It won't seize up and snap a belt will it?
Reply #1May 24, 2009, 07:19:36 am
rallydiesel
  • 1880
Re: A/C Removal
« Reply #1 on: May 24, 2009, 07:19:36 am »
I removed my compressor. It could possibly seize. Also it's fairly hefty and getting rid of it allows to remove a v-belt. You'll need a non-a/c alternator though if you want to go this route.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2May 24, 2009, 04:51:01 pm
mystery3
  • 774
Re: A/C Removal
« Reply #2 on: May 24, 2009, 04:51:01 pm »
I'm aware of the virtues of the non-a/c alternator but don't have one handy. I'd like to eliminate as much of the system as possible for the time being and eventually find a non-a/c alternator and clean it up properly.
Reply #3June 07, 2009, 05:52:50 pm
madmedix
  • 204
Re: A/C Removal
« Reply #3 on: June 07, 2009, 05:52:50 pm »
Let me tell you a little story...I did not remove my AC compressor in my (RIP) 92 Golf NA. One day, she was really losing power. Then I smelled it....then saw the cherry red compressor staring at me when I opened the hood. There was no fire extinguisher in her at the time and no source of fluid to cool off the compressor that was glowing cherry red and had melted the belts. Good thing I drank a few coffees on the way...that's how I put her out  ;D
Yes, it will seize. Get it out of her  ;)
'90 TD Jetta
Reply #4June 08, 2009, 04:49:05 pm
Re: A/C Removal
« Reply #4 on: June 08, 2009, 04:49:05 pm »
the only way that the a/c compressor is engaged is if the clutch is energized.  the clutch shouldn't energize unless the low pressure switch is bad, and you've selected defrost.
just make sure to cut and insulate the clutch wire, and it should be fine.
Reply #5June 09, 2009, 03:05:58 pm
79rabbit4dr
Re: A/C Removal
« Reply #5 on: June 09, 2009, 03:05:58 pm »
I bet that smelled REAL nice  ;)
