Author Topic: Where can I get a multi stage chip device for my 2000 jetta TDI?  (Read 2746 times)
May 23, 2009, 07:01:52 pm
bigblockchev
  • 271
I have heard that such things are available to adjust the power increase as circumstances require. Anyone have any direct experience with such devices. Other comments regarding simple power increase possibilities would be appreciated. Bigger injectors ? Turbos ? whatever works for a modest power gain that is easily reversible. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #1May 24, 2009, 05:36:56 pm
gigaz2
  • 626
Re: Where can I get a multi stage chip device for my 2000 jetta TDI?
« Reply #1 on: May 24, 2009, 05:36:56 pm »
"adjust the power increase as circumstances require"
well.. there is a lever under your right foot...
you can always make or get a switchable evrymod.
I made a simple switch to work on a bmw tds (same ecu system as early tdis) the "rear electric windows lock" switch became a selector between stock chip and a preformance one, 90Hp/117Hp, is that kind of a system you were thinking?
