General Information
Troubleshooting
transmissions for rwd application on a 1.6td
Pages:
Topic: transmissions for rwd application on a 1.6td (Read 9080 times)
Reply #15
June 05, 2009, 04:17:32 pm
bigblockchev
Thread hijack
Reply #15 on:
June 05, 2009, 04:17:32 pm »
Coolest thing I ever saw was a Datsun 240Z with a Datsun 6 cyl diesel in it. All stock Datsun parts. Cool but wierd. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan MDJF 15Kw genset
Reply #16
June 19, 2009, 07:51:22 pm
Aaron R
Re: transmissions for rwd application on a 1.6td
Reply #16 on:
June 19, 2009, 07:51:22 pm »
What about using an Audi Quattro transmission and not use the front drive flanges? You could use the driveshaft and independant rear suspension.
I've always wanted to build a rear wheel drive fox this way.
Reply #17
June 21, 2009, 01:54:18 am
Reply #17 on:
June 21, 2009, 01:54:18 am »
i wonder if you can get the conversion kit for the 1.6 to fit up to a Zuk (tracker) trans and the shove the tracker trans into the VW
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
Pages:
General Information
Troubleshooting
