Author Topic: AHL TDI into Caddy  (Read 3004 times)
May 08, 2009, 04:21:52 am
dieselherb1
  • 354
AHL TDI into Caddy
« on: May 08, 2009, 04:21:52 am »
I have a 2000 AHL engine may put into a caddy in the future. Looks alot different compared to a 1Z! Will it work with a AAZ pump? It came from a Jetta that had a underhood fire.
Reply #1May 08, 2009, 05:53:06 am
Spulen81
  • 103
AHL TDI into Caddy
« Reply #1 on: May 08, 2009, 05:53:06 am »
I'm not a M-TDI head but I don't think it'll work for two reasons.  First the "hub" size where the pump fits in the IP mount is smaller than an ALH pump.  You could probably get an adapter ring machined though.  The next problem is setting the timing.  ALHs use an adjustable IP pulley, AAZs require moving the whole pump.
RabbitGTDguy for example used a cummins 4B pump and use a ALH adjustable pulley.  So maybe using a cummins pump as a base is the way to go.
'86 4Runner TDI SOLD
'91 GTI - TDI converted
Reply #2May 22, 2009, 07:34:16 pm
oldskool rich
  • 446
Re: AHL TDI into Caddy
« Reply #2 on: May 22, 2009, 07:34:16 pm »
ive done exactly that, im running a disco pump (same hub width as an AAZ) on a BKD that is built to be like an ALH, i took the pully to my local machine shop and he made the ALH pully fit, it cost £20
AAZ pump will work but wont be all that good, i dont think they have as much advance as a TDI pump
f6squared I.D.S.T
Reply #3May 23, 2009, 07:41:12 am
dieselherb1
  • 354
« Reply #3 on: May 23, 2009, 07:41:12 am »
Rich,
Sorry but I don't know what a "disco" pump is or a BKD. Could you explain?
Thanks
