Author Topic: egr?  (Read 3676 times)
May 05, 2009, 07:24:16 am
BPONCI
  • 4
egr?
« on: May 05, 2009, 07:24:16 am »
Can i install a egr blockoff plate to shut down the flow gonig thru the intake without tripping a check engine light? TIA!!!!!
1996 DODGE 4X4 TWINS
1994 DODGE 4X4 LOWERED,TWINS,FULL BILLET TRANS RUNS [email protected] MPH
2003 JETTA TDI INTAKE,CUSTOM EXHAUST, BOOST AND PYRO GAUGES, BD X-POWER MODULE,RIDES ON 18'S.
Reply #1May 05, 2009, 07:53:35 am
  • 3255
    • My collection of HOWTOs
egr?
« Reply #1 on: May 05, 2009, 07:53:35 am »
Nope, you'll throw a code and it will keep coming back.
The trick seems to be to leave the EGR physically in place *but* turn the duty cycle down to the point where it's basically not on.
My car came with this "feature" already done by the dealer... the boys over at TDIclub.com probably have the required VagCom steps.
Reply #2May 05, 2009, 08:45:33 am
egr?
« Reply #2 on: May 05, 2009, 08:45:33 am »
sometimes the egr can leak a little, so a block off plate isn't a bad idea.
Reply #3May 05, 2009, 09:00:22 pm
diesel smoke
  • 209
egr?
« Reply #3 on: May 05, 2009, 09:00:22 pm »
It's VERY easy to delete the EGR and not have a CEL. Unplug the vac line from the EGR valve and plug it with something. You got to get into VCDS, engine, measuring blocks, block 3. Then you take out the 2 safety screws holding the MAF sensor in the base. Then turn the MAF sensor CCW until the actual reading is a bit lower than specified at idle. Clear all codes and you are good to go. I have been running around like this for almost a year.  8)
We had a thread on TDIClub. http://forums.tdiclub.com/showthread.php?t=219593
Also, if you have the EGR adaptation on the 'off-road' adaptation (the lowest EGR flow) the computer retards the timing and mileage suffers. Leave it stock and twist the MAF.
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
