Author Topic: Charging woes!!  (Read 4967 times)
May 04, 2009, 07:25:56 pm
Hammy
  • 169
Charging woes!!
« on: May 04, 2009, 07:25:56 pm »
I have a '91 Golf, 1.6, with the 'W' connection. I'm having a problem with it charging. Sometimes it does, sometimes not. I can tell if it is not charging, as the tach stops working, then I check it with a multimeter. I can get it to charge if I apply power to the field.
 What controls the field excitation?
Thanks;
Hammy
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
Reply #1May 04, 2009, 07:39:04 pm
Charging woes!!
« Reply #1 on: May 04, 2009, 07:39:04 pm »
D+ terminal at the alternator via a blue wire to the "BAT" LED on the cluster.
Very interesting problem. ;-)
Are you getting a consistent "BAT" light when you turn the car to "ON" ?  Does the "BAT" light come on when the tach stops?
Reply #2May 04, 2009, 07:59:42 pm
camboscams
  • 324
Charging woes!!
« Reply #2 on: May 04, 2009, 07:59:42 pm »
Not to thread jack, but while were on the subject... My batt light stays on all the time. No tach in car, just clock. No "w" connecter
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #3May 05, 2009, 06:43:04 pm
Hammy
  • 169
Charging woes!!
« Reply #3 on: May 05, 2009, 06:43:04 pm »
Thanks for the reply Vincent. As for the battery led, (I just noticed) it doesn't come on at all. Is there a relay in the car that excites the field?
Thanks;
Hammy
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
Reply #4May 05, 2009, 07:16:20 pm
Charging woes!!
« Reply #4 on: May 05, 2009, 07:16:20 pm »
Nope, the alternator is excited simply by current flow thru the dash LED.  No LED, no excitation is taking place.
After checking for the obvious things, specifically a loose blue wire at the alternator, you can isolate the issue by removing the blue wire from the alternator and grounding it.  The BAT LED should now come on when you turn the key to the ON position.
If it doesn't, there's a problem upstream... the wiring to the cluster or the cluster itself.  Since it's a LED it rarely burns out... connection issues are more likely.
If it does, the problem is downstream... ie the alternator itself.
BTW, the voltage regulator is internal and so you don't actually have access to the field windings; at least not without surgery.   If you've been supplying voltage to the blue wire and getting it to charge you've been exciting your alternator manually. :wink:
Reply #5May 05, 2009, 08:09:38 pm
Hammy
  • 169
Charging woes!!
« Reply #5 on: May 05, 2009, 08:09:38 pm »
Thanks again Vincent. I'll give that a once over tomorrow.
Jas
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
Reply #6May 24, 2009, 12:49:04 pm
Hammy
  • 169
Re: Charging woes!!
« Reply #6 on: May 24, 2009, 12:49:04 pm »
 Ok, it's been awhile! LOL! Anyways, I still don't get a battery led light on the dash. But, I installed a new alternator, and my charging problem appears to be fixed. Now I tried grounding the blue wire, still no light. I wonder if it could be the led, maybe it's in parallel with the circuit, therefore the field still gets excited. I had power on it it once the alternator started charging, so it must be the led, or something in the cluster itself?
Thanks;
Jas
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
