Author Topic: FS 1.6 diesel parts, cleaning up CHEAP  (Read 5783 times)
May 04, 2009, 05:07:28 pm
houseofdiesel
  • 210
« on: May 04, 2009, 05:07:28 pm »
I have assembled a nice pile of 1.6 diesel parts, I don't need it anymore
NON turbo ME code stuff
valve covers $2
oil pans $4
injector cores $1
glow plugs tested working $4
pulleys $2 -cam -crank for t belt -crank for vbelt -waterpump -injpump
intermediate shaft pulley $5 (alloy)
timing belt inner covers $1 steel
timing belt upper covers $1 plastic
intake manifolds $2
air box $2
cylinder heads will provide more details, some rebuilt
Short block, CODE CS from Vanagon diesel with oil squiter for pistons for cooling, $50 each (two)
Short block, CODE MF turbo diesel $50 one only
More to come as I trip over it in the garage. All the parts were inside for the last few years and I just finished/sold my last 1.6 diesel project. I am willing to ship/paypal no problem, I have limited time so I will try my best to be quick/fast, I will be upfront with shipping times etc. I am in the Ottawa Ontario area.
Greg
Reply #1May 04, 2009, 06:18:14 pm
« Reply #1 on: May 04, 2009, 06:18:14 pm »
PM sent about injector cores
Reply #2May 07, 2009, 08:26:23 am
houseofdiesel
  • 210
« Reply #2 on: May 07, 2009, 08:26:23 am »
Two rebuilt cylinder heads (resurfaced, valve seals, valve guides if needed, etc, not a top notch rebuild just what was needed) ending in part number M, solid lifter, non turbo probably off Vanagon CS motors.
One sad looking hyd turbo head, part number ends in T, pitted gasket surfaces, no prechambers installed, I might resurface to see what lies beneath right now it is sooty and sad looking
Reply #3May 08, 2009, 05:59:14 am
« Reply #3 on: May 08, 2009, 05:59:14 am »
Please let me know about the injector cores. IF they are turbo or not and if they are a dollar a piece I want them regardless. I already sent you a PM Lucas
Reply #4May 21, 2009, 09:47:04 pm
Dakotakid
  • 1240
Re: FS 1.6 diesel parts, cleaning up CHEAP
« Reply #4 on: May 21, 2009, 09:47:04 pm »
Hello:
When you say "airbox," do you mean just the lid/top cover or do you mean the base and lid????
Which model of airbox do you have.....the 6 clip (4 plus 2) or just the 4 side clips model??? The 4 clip model opening (where you place the air filter element) sits much more verticle on the manifold AND the 4 clip model is what I am interested in getting (need the base and lid).
Reply #5May 21, 2009, 11:48:52 pm
billybobf
  • 318
« Reply #5 on: May 21, 2009, 11:48:52 pm »
Hey, totally interested in an oil pan, four injectors, upper and lower timing covers
and maybe thats it for now, unless you have a complete water pump housing with the water pump and thermostat housing, let me know what you can get me and a total shipped to US zip code 96007
Reply #6May 22, 2009, 03:40:25 pm
houseofdiesel
  • 210
« Reply #6 on: May 22, 2009, 03:40:25 pm »
I will be adding to the pile this weekend, let me figure out what I have in terms of air boxes and injectors etc. I will take some pics also. I should have some waterpumps too, but I might have tossed them to scrap already.
Greg
Reply #7May 23, 2009, 09:10:28 am
« Reply #7 on: May 23, 2009, 09:10:28 am »
nevermind on the injectors I have found a guy that will ship them as I needed. Thanks Lucas ><>
« Last Edit: May 23, 2009, 02:15:04 pm by theman53 »
Reply #8June 03, 2009, 05:04:30 pm
Laurentian
« Reply #8 on: June 03, 2009, 05:04:30 pm »
Test, am having trouble posting.
OK, got it!
Need a crank pulley for 1.6D / 1.6TD with pwr steering.
Need that for a AAZ set-up using MKII V-belt set-up.
Thanks,
Hugh
[email protected]
« Last Edit: June 03, 2009, 05:06:23 pm by Laurentian »
Reply #9June 06, 2009, 04:07:36 pm
VillageIdiot
  • 1
« Reply #9 on: June 06, 2009, 04:07:36 pm »
Hi I am wondering if you have an upper timing belt left before I lose my fingers. I might be interested in a cylinder head depending on what I hear back from my machine shop. Thank you
