Author Topic: burning smell after timing belt change  (Read 5353 times)
May 02, 2009, 09:30:33 am
catlin_cava
  • 1954
« on: May 02, 2009, 09:30:33 am »
I'm looking At a 95 golf and after the guy changed the timing belt he said it smells like burning wires inside? why?
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1May 02, 2009, 11:29:37 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #1 on: May 02, 2009, 11:29:37 pm »
could have the tensioner on backwards rubbing like CRAZY on the timing belt.
you should also probably hear a high pitch squeel if that is happening though... unless he doesn't know what a diesel sounds like and just thinks the screaming sound is normal (had that happen to my car once before  :roll: . I come out side... "Wait what is ... SHUT IT OFF!!! Belts are rubbing!"
Ed
Reply #2May 03, 2009, 06:06:49 am
catlin_cava
  • 1954
« Reply #2 on: May 03, 2009, 06:06:49 am »
Its a 2.0l Gasser, and there was smoke inside the car and now it won't start anymore, will turn over but not start. I was looking at buying it for a second car
Catlin
Reply #3May 03, 2009, 07:01:07 am
« Reply #3 on: May 03, 2009, 07:01:07 am »
I haven't done a gasser, but I would imagine if the cover is like the one on my diesel it can be missaligned a little. Then it rubs and could smoke. Why it wouldn't start I don't know, unless he did some other work when doing the timing or it slipped a little and won't run? just guesses.
Reply #4May 03, 2009, 10:41:32 am
rabbitman
  • 2788
« Reply #4 on: May 03, 2009, 10:41:32 am »
If he smelled burning wires and got smoke INSIDE the car, then I would say some wires def got burned so they would need to be found and new wires ran.
Reply #5May 03, 2009, 01:52:19 pm
Smokey Eddy
  • 3468
« Reply #5 on: May 03, 2009, 01:52:19 pm »
yeah sorry i assumed you were talking about a diesel... :roll:  (little to no wiring on our IDI's :P )
Ed
