Author Topic: Crap for sale, get it while it's hot!!!  (Read 4005 times)
April 26, 2009, 03:42:51 pm
maxfax
  • 2126
« on: April 26, 2009, 03:42:51 pm »
Ma & Pa are selling the farm, time to ditch my stockpile..  I got too much around to list everything but here's a general idea.. If you need somethign specific, please ask..
I'm open to reasonable offers, not sure what to ask for some of this (help on this would be appreciated)..   I can take paypal, MO, heck I'll take a check but will wait till it clears to ship.. I'm located at zipcode 17082 if you are interested in pickup or want to ge an idea of shipping..   PM me here or email [email protected]..
Okay here we go..
1980 1.5L Crank rods & pistons (TB sprocket included) The car had 468K miles on the clock, still ran and had oil pressure, and standard bearings..  (Block was cracked).. Unfortunatley from sitting around here there is some surface rust on the crank..  No severe pits that I can see, it might polish up but I'm going to say it shoudl be turned..  Pistons look fair, no valve imprints but I haven;t measured them..
11mm 1.6 Head complete with cam..  I'll be darned I can;t see any crackes between the valves, must have been a replacement head at some point..  The car had oil in the coolant, Unknown miles..  SOmeone used tons of goo on the HG and gasser head bolts..   Dunno if it has been overheated or not.. Assume it needs surfaced...
1984 1.6 TD IP pump lines & injectors..   Car hasn;t been run since 2005..  Pump is still on the car and connected but full of diesel  :( .. Car was parked due to rust and low compression..
Random NA IP's..  I know nothing about these.. I have about 3.. One is MK2 the others are MK1..  They been sitting a while, no ports covered..  SPare parts or cores at best... Have some NA lines and injectors that could be cores too..
Random valve covers, oil pans (I do have the TD oil pan and cooler too), Front and rear seal holders.. Accessory brackets (mostly MK1 some for A/c) Intermediate shafts, TB sprockets.. N/A MK1 and II intake and exhaust manifolds..  Some random A/C components too..
Got an entire 84 jetta..  Grill is typically gone, tail lights and front markers look usable.. The Blue Interior doesn;t look too bad other than the seats and center console.. Some doors, bumpers, decklid, hood, maybe fenders.. Email with needs
Have an 85 jetta, about the same as above...
Have a few MK1 rabbits here for pieces too.. Consider most of the body panels and lights crap..  Got plenty non A/C coling fans and a 4speed transaxle (not sure of code)..
There's just so much to go through and list please feel free to ask..
Reply #1April 26, 2009, 06:32:17 pm
hamradio
  • 282
« Reply #1 on: April 26, 2009, 06:32:17 pm »
How much for a set of questionable td injectors?
Reply #2April 26, 2009, 06:53:07 pm
maxfax
  • 2126
« Reply #2 on: April 26, 2009, 06:53:07 pm »
Considering them as rebuildable cores, what's a core charge on these generally??  $10 - $15 a piece maybe??  Not sure if I'm in line with that or not
Reply #3April 28, 2009, 02:40:29 pm
maxfax
  • 2126
« Reply #3 on: April 28, 2009, 02:40:29 pm »
BUMP
Got some crappy news from the machine shop..  I'm willing to wheel and deal for a servicable 1.6 crank... Don;t care if it's the early or late style..
Reply #4April 28, 2009, 11:03:18 pm
billybobf
  • 318
« Reply #4 on: April 28, 2009, 11:03:18 pm »
how much for the TD pump?  shipped to anderson ca, should fit in the largest flat rate box from usps
Reply #5April 29, 2009, 06:59:08 pm
maxfax
  • 2126
« Reply #5 on: April 29, 2009, 06:59:08 pm »
PM sent..
Reply #6April 30, 2009, 08:31:49 am
allsierra123
« Reply #6 on: April 30, 2009, 08:31:49 am »
Have any Junk TD pumps I can Use the top off of?
Reply #7April 30, 2009, 09:52:08 am
smoken u
  • 231
« Reply #7 on: April 30, 2009, 09:52:08 am »
in your random pile of valve covers you wouldnt happen to have one from a G60  lying around would you ???
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
