Author Topic: Injection pump resealing problems.  (Read 3744 times)
April 26, 2009, 12:03:57 pm
Jesse H.
  • 2
« on: April 26, 2009, 12:03:57 pm »
Hi, I resealed a 1.6 n/a pump and now it won't suck in fuel.  I assume the feed pump is the problem.  I know that the feed pump vanes are not in their original slots.  Is this critical?  I took the pump back apart to make sure that the feed pump pressure plate screws weren't to tight causing the vanes to stick.  They moved freely.  I reassembled and reinstalled the pump, but still no joy.  Any help would be most appreciated.  BTW, this is the second pump that I have tried and both have the same problem.  At least I'm consistent.
Reply #1April 26, 2009, 12:55:08 pm
« Reply #1 on: April 26, 2009, 12:55:08 pm »
Are you getting good flow thru the pump to the OUT bolt when you crank?  If so, the vane pump is not the issue.
Reply #2April 26, 2009, 07:15:53 pm
Jesse H.
  • 2
« Reply #2 on: April 26, 2009, 07:15:53 pm »
I primed the pump through the OUT hole.  Then I bled the injector lines.  The fuel line from the filter to pump input is clear and there is no fuel in it.  If I have something 180 out would that cause this problem?
