Author Topic: looking for torque specs for a 1.9L TD  (Read 2822 times)
April 25, 2009, 12:48:19 am
Golf/Jetta
  • 102
« on: April 25, 2009, 12:48:19 am »
cam bearing nuts - 20Nm (14 ft lb)
intermediate pully/sprocket bolt 65 - 80 Nm (48 - 58 ft lb)
Quote from: "Vincent Waldon"
Can't recommend you save your money and get the Bentley strongly enough... the Haynes pales in comparison and will let you down again and again as you get deeper and deeper into wrenching your car.. which I can tell you will !!
I'll happily look up whatever settings you need as you do your headgasket if you solemnly promise me you'll save your sheckles and get a Bentley.  BTW you'll also need the correct tightening sequence... which is also the correct loosening sequence... you need to slowly remove the old head as well so that it doesn't warp.
Loosen the bolts in the above sequence, 1/4 or 1/2  turn at a time.
The new gasket goes on dry.  The tightening sequence is:
1) 40 Nm
2) 60 Nm
3) additional 1/4 turn
4) additional 1/4 turn
5) run the engine up to operating temp then an additional 1/4 turn
6) for ME and MF engines, an additional 1/4 turn after about 1600 km
Friends don't let friends buy Haynes or Chiltons  :wink:
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
