Author Topic: Electronic VNT control DIY  (Read 47031 times)
Reply #30September 23, 2009, 03:33:37 pm
Les
  • 13
Re: Electronic VNT control DIY
« Reply #30 on: September 23, 2009, 03:33:37 pm »
How do you measure IQ?
98 Suzuki Sidekick converted to diesel (94 VW Golf 1.9 TD AAZ Engine), 5" lift, 31" tires, Petroworks Hi Perf. Clutch
Reply #31September 23, 2009, 05:09:05 pm
starrd
  • 128
« Reply #31 on: September 23, 2009, 05:09:05 pm »
On the "TDI" the third injector has a sensor built into it.
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #32September 24, 2009, 09:30:14 am
Les
  • 13
« Reply #32 on: September 24, 2009, 09:30:14 am »
So how would we measure the IQ on TD engine? Any injector mod? or using TDI injector?
Reply #33September 24, 2009, 06:58:13 pm
monomer
  • 414
« Reply #33 on: September 24, 2009, 06:58:13 pm »
Hey,
   on instructables there is a DIY for turning a laserjet printer into a PC board printer. It would save you the cost on caustic chemicals and all those wonderful smells associated with making your own boards.
http://www.instructables.com/id/5pcb/
you are still required to etch the board. They use ferric chloride, as listed on the front page.
www.michiganvw.org
Reply #34September 25, 2009, 04:04:34 am
  • 3468
    • McScrubbins Body Wash
« Reply #34 on: September 25, 2009, 04:04:34 am »
easily in the top 5 most amazing and impressive threads i've seen on not only this forum but all of the internets.
hats off to you dude.
Reply #35September 25, 2009, 05:23:55 am
macka
  • 957
« Reply #35 on: September 25, 2009, 05:23:55 am »
Hey,
Honestly I have never made my own board, and didn't really read it. I just saw it on my instructables email and thought it would be right up Hey's alley.
Quote from: Vincent Walden
Reply #36September 25, 2009, 05:49:45 am
regcheeseman
  • 714
« Reply #36 on: September 25, 2009, 05:49:45 am »
Excellent work,  ;D
Could I possibly get the schematic file of the TD circuit? I use ARES and ISIS as my design package but have access to others.
I would like to modify the circuit slightly for different sampling and control with maybe a tacho driver as well.
I have access to a PIC devolopment system but have no experience of HEX code, can you give me an idea of how your program works? does it contain a simple map?
Thank you.
Hi,
I've roughed out a basic schematic for a TD controller, am hoping to drive a tacho but with bargraph for VNT position and a digital boost display.
I've downloaded MPLAB and disassembled your code (to no avail) I'm not intending to market anything, and any developments made on a TD version will be documented and freely distributed on this site and others. Any help you can offer regards reverse engineering would be excellent.
Yes Badboy - I'll make you one too!
Reply #37November 08, 2009, 08:17:16 pm
monomer
  • 414
« Reply #37 on: November 08, 2009, 08:17:16 pm »
how about an Arduino based controller?
I've just learned of this PIC replacement, and it's an all-in-one kit, I bet we could make it so no PCB's would have to be etched!
www.michiganvw.org
Reply #38December 01, 2009, 04:27:46 pm
ohc
  • 13
« Reply #38 on: December 01, 2009, 04:27:46 pm »
An Arduino should more than do the trick. It might be considered overkill, but could also add some very interesting possible features, like a display and laptop connectivity. Change up your software, upload it via laptop and 'reboot' the car and you'd be ready to go. The dev environment is also really easy and that community is huge. Probably lots of help. Not that i've done more than blink a couple LED's with one but it would be a great alternative to a custom built board and offer loads of flexibility.
That said, what Hey is doing is REALLY COOL! I'm very excited about it.
Reply #39July 09, 2010, 12:16:47 am
Dreamza
  • 1
    • Control valve
« Reply #39 on: July 09, 2010, 12:16:47 am »
Electronic VNT control DIY.
A glass to have the acetate match the board perfectly. VERY higly IMPORTANT.
newbielink:http:// www.intech2000.com [nonactive] : newbielink:http:// www.intech2000.com [nonactive]
Reply #40July 09, 2010, 01:40:14 am
anto
« Reply #40 on: July 09, 2010, 01:40:14 am »
Some idi engines had an injector measuring injector lift;
eg Peugeot 406 turbo diesel.
Reply #41May 31, 2013, 10:59:33 am
« Reply #41 on: May 31, 2013, 10:59:33 am »
Has anyone built one of these recently? :)
Reply #42May 31, 2013, 02:21:22 pm
rumbling_caddy
  • 80
« Reply #42 on: May 31, 2013, 02:21:22 pm »
Thanks for sharing.   I might have to give this a try later in the summer.  I wonder if a circuit can be drawn
with this conductive paint stuff.
http://www.thinkgeek.com/product/eb92/
Reply #43May 31, 2013, 02:46:51 pm
damac
  • 531
« Reply #43 on: May 31, 2013, 02:46:51 pm »
Im surprised somebody smart doesn't sell kits for these turbos for dummies like me that just want to buy the parts, follow the directions and install.  Because I don't understand the techie stuff :)
This is the reason I only have stock junk on my 1.6td, would love to buy a kit to install, then take it down to the exhaust shop to have a custom fit kit made.  I hate the t3 turbo in my car :)
1985 turbo diesel jetta
Reply #44May 31, 2013, 04:12:46 pm
wolf_walker
  • 1205
« Reply #44 on: May 31, 2013, 04:12:46 pm »
Kinda where I am too.  I could figure it out with the help of a few people I know, but I'm just not that motivated.
I would however spend money on a pre-figured solution.  I'm sure it'll happen eventually.
Mentat Text Two
