Author Topic: TDI bottom end, 1.6 head?  (Read 2909 times)
April 22, 2009, 08:08:07 pm
hamradio
  • 282
« on: April 22, 2009, 08:08:07 pm »
So,
From what I understand, I could get a late '90s 1.9 tdi bottom end, aaz pistons and rods, a 1.6 head, throw it all together, and it would work?
What would the CR come out to?  Would I have to use a hydro head, or could I use mech?  Additionally, could I use an aaz head?
Lastly, would the block have provisions for a normal IP bracket to bolt to?
I ask this, because I could get a 1.9tdi block from a car that blew a tbelt for cheap.
Thanks.
Reply #1April 23, 2009, 08:54:51 am
hamradio
  • 282
« Reply #1 on: April 23, 2009, 08:54:51 am »
32 views and nothing?!  :D
Reply #2April 23, 2009, 08:57:33 am
Baixo
« Reply #2 on: April 23, 2009, 08:57:33 am »
im no expert so i wont say that it will  or wont work.
but what we all know is that the 1.9 is better then the 1.6.
i myself would not be inclined to use a 1.6 head on a 1.9 bottom end.
Reply #3April 23, 2009, 09:24:43 am
hamradio
  • 282
« Reply #3 on: April 23, 2009, 09:24:43 am »
Thanks.  I think the bottom end is an AHU, but *might* be an ALH.  Is there a difference between them?  How strong are the stock tdi rods vs aaz ones?
Reply #4April 23, 2009, 09:32:54 am
saurkraut
  • 904
« Reply #4 on: April 23, 2009, 09:32:54 am »
1.9 block with 1.6 head CR 27.26:1   :shock:
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #5April 23, 2009, 09:47:29 am
hamradio
  • 282
« Reply #5 on: April 23, 2009, 09:47:29 am »
D'oh.
Would it be the same with aaz pistons as it would with tdi?
Reply #6April 23, 2009, 12:11:17 pm
« Reply #6 on: April 23, 2009, 12:11:17 pm »
wasn't there a 1.6 upgrade to 1.9 by just using the bottom end? a little counter productive though because the 1.9 head flows sooo much better...
Reply #7April 23, 2009, 01:12:03 pm
hamradio
  • 282
« Reply #7 on: April 23, 2009, 01:12:03 pm »
Would the 1.9 head do alright?
Reply #8April 23, 2009, 01:57:41 pm
« Reply #8 on: April 23, 2009, 01:57:41 pm »
Quote from: "hamradio"
yep.  the 1Z/AHU is nearly identical to the AAZ other than some of the internals.  jimfoo turned his broken 1.9 AAZ into a TDI by just adding TDI pistons & head.  he even used the AAZ head internals in the TDI head and it worked.
