Author Topic: Intake hose popping off turbo?  (Read 3801 times)
April 22, 2009, 04:50:18 pm
commuter boy
  • 277
« on: April 22, 2009, 04:50:18 pm »
Never really seen this before, the intake hose on my '97 AAZ Golf keeps popping off the turbo.
I screw it down snug but 10 minutes later it's slid off again.  Anything I should be looking at?  The airbox is seated in it's locating hole, the crank vent hose seems to be fully seated.  I'm not sure what else could be causing the problem.
I don't want to reef on the thing and cut off the end, but I'm getting a little perturbed.
Reply #1April 22, 2009, 05:28:15 pm
« Reply #1 on: April 22, 2009, 05:28:15 pm »
Are you sure it is sliding on all the way? Sometimes the clamp hits the wastegate fittings and stops the hose from sliding home.
Reply #2April 22, 2009, 06:41:33 pm
commuter boy
  • 277
« Reply #2 on: April 22, 2009, 06:41:33 pm »
Nope, all the way in, I needed to rotate the clamp around a bit to get it fully seated.
Reply #3April 22, 2009, 06:46:22 pm
OmnibusX
  • 39
    • http://www.youtube.com/user/OmnibusX
« Reply #3 on: April 22, 2009, 06:46:22 pm »
check for oil and change the clamp
94 VW Golf GL MK3 1.9 TDK
85 Toyota Corolla 1.3
86 VW Golf CL MK2 1.8
89 Peugeot 205 GTI 1.6
84 Peugeot 205 GTI 1.6
Reply #4April 22, 2009, 09:48:00 pm
commuter boy
  • 277
« Reply #4 on: April 22, 2009, 09:48:00 pm »
That just might be it.  The clamp's a standard sized Tridon, not the VW one which is slightly skinnier, so it's not seating in the groove.
I must have grabbed the wrong one when I changed the head gasket not long ago.
Thanks for the ideas!
