Author Topic: top out at 150?  (Read 3638 times)
April 19, 2009, 04:16:00 pm
catlin_cava
  • 1954
top out at 150?
« on: April 19, 2009, 04:16:00 pm »
I wanted to see what the poor thing could do and it topped out at 150kph and at 4100rpm and it stopped climbing...could it be its got a governer? :shock:
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1April 19, 2009, 05:47:21 pm
bigblockchev
  • 271
top out at 150?
« Reply #1 on: April 19, 2009, 05:47:21 pm »
If you are referring to the 97 with an AAZ motor, they run out of oomph bigtime above 4000 rpm. Perhaps your IP has a weak overspeed governer setup. It certainly feels that they should be able to pull somewhat higher revs. My 93 drops off like a stone above 4000 while my 92 will rev much higher. Cheers Dan
it's always something simple
one test is worth a thousand guesses
95 Chev Suburban 6.5 w performance mods
91 Mercedes 300D 603.960 6cyl 3L
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
5.5 years and counting on B100
Reply #2April 19, 2009, 06:00:24 pm
catlin_cava
  • 1954
top out at 150?
« Reply #2 on: April 19, 2009, 06:00:24 pm »
I find it funny that it does that, it climbs up to 4000 just fine and it stops...foot to floor no more fuel...I think i should push a diesel with 368,000km that hard :lol: but I am known for blowing up cars :twisted:
Catlin
Reply #3April 19, 2009, 06:22:21 pm
Op-Ivy
  • 513
top out at 150?
« Reply #3 on: April 19, 2009, 06:22:21 pm »
This is why it stops fuelling. http://www.youtube.com/watch?v=6j0vrfaXPmw
Reply #4April 19, 2009, 06:35:29 pm
catlin_cava
  • 1954
top out at 150?
« Reply #4 on: April 19, 2009, 06:35:29 pm »
How do I fix that? I need power :twisted: I can't even keep up to my gf's accent on the highway :shock:
Catlin
Reply #5April 19, 2009, 07:31:43 pm
scottcoreyv
  • 5
top out at 150?
« Reply #5 on: April 19, 2009, 07:31:43 pm »
The Governer mod helps alot, I can rev my AAZ to 5200rpm no problem.
Reply #6April 19, 2009, 07:36:24 pm
top out at 150?
« Reply #6 on: April 19, 2009, 07:36:24 pm »
http://mebonty.monobasin.net/vepump.html
http://www.vwdiesel.net/phpBB/viewtopic.php?t=2300
Both found in the FAQ. The 2nd link is not quite right. Don't touch the Intermediate spring (the one in the middle) Just shim the main spring about 1/4". This will help you not to shut down fueling. Also take pictures of the top of your pump before you touch it, this will help to put it back together. The 2nd link is good for its pictures and may help you to ask the correct questions if needed. Regular washers are acceptable for shims. Have fun.
Reply #7April 19, 2009, 07:44:24 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
top out at 150?
« Reply #7 on: April 19, 2009, 07:44:24 pm »
mine [1.6 bottom 1.9 top] will go 170+ i've yet to reach my top speed.
Ed
Reply #8April 19, 2009, 08:55:07 pm
Op-Ivy
  • 513
top out at 150?
« Reply #8 on: April 19, 2009, 08:55:07 pm »
Just a question... When you say you are topping out at 150kmph, what gear are you in? What transmission do you have?
Reply #9April 20, 2009, 02:27:14 am
catlin_cava
  • 1954
top out at 150?
« Reply #9 on: April 20, 2009, 02:27:14 am »
I'm in 5th and i have the original tranny on it. at around 3600 it starts slowing up and stops at 4000, my foot is right on the floor, I'm starting to think my motor is worn out.
Catlin
Reply #10April 20, 2009, 03:59:42 am
Smokey Eddy
  • 3468
top out at 150?
« Reply #10 on: April 20, 2009, 03:59:42 am »
Quote from: "catlin_cava"
What exactly do you mean by that?
Ed
Reply #11April 20, 2009, 05:13:01 am
carrizog60
  • 978
top out at 150?
« Reply #11 on: April 20, 2009, 05:13:01 am »
did you check that you have full travel on gas pedal?
with a 4S i can take mine to +200km/h and past 5000rpm...
on my moms golf 3 1.9D i have taken it several times on highway to the point it doesn't rev more,burring the rpm needle on the red scale :twisted:
you my friend,you got a problem :arrow:
Portugal
Reply #12April 20, 2009, 04:22:46 pm
catlin_cava
  • 1954
top out at 150?
« Reply #12 on: April 20, 2009, 04:22:46 pm »
with 368,000 km on it, the block never openned up,
Catlin
Reply #13April 20, 2009, 06:20:22 pm
top out at 150?
« Reply #13 on: April 20, 2009, 06:20:22 pm »
368,000 aint that much really.. I dunno.. I knew the gov starts to cut fueling.. but not so much that it just stops going up.. usually its to the point where it will climb slowly but steadily no?
Reply #14April 20, 2009, 08:41:24 pm
maxfax
  • 2126
top out at 150?
« Reply #14 on: April 20, 2009, 08:41:24 pm »
Does it still start decent in cold weather???  That isn't really that high of milage err I guess kilometerage for one of these... Even beating the hell out of it....  The 1.5 in the ole Frankenbunny had 546,00 miles (885,000 kms)  Ran about the same as yours till I had the pump rebuilt..   Ran fairly well after that till the HG blew and it got freshened up..
Unless you have low gears (what's the code on your trans?) Your pump just may need some molestation...   Time to call Giles...
