Author Topic: anyone have any pics of there aaz serpentine setup.  (Read 4418 times)
April 16, 2009, 07:05:32 pm
allsierra123
« on: April 16, 2009, 07:05:32 pm »
I am thinking my belt may be too short or I have it on wrong. Its not touching the water pump pulley at all.
Reply #1April 16, 2009, 07:34:54 pm
allsierra123
« Reply #1 on: April 16, 2009, 07:34:54 pm »
I think I may have got the belt for the non AC engine.
Reply #2April 17, 2009, 10:00:03 am
flapjack
  • 283
« Reply #2 on: April 17, 2009, 10:00:03 am »
From what I've seen, you can't run AC and the waterpump with the serpentine belt.
If you run AC, then the waterpump shares a separate V belt with power steering.
signature
Reply #3April 17, 2009, 10:09:49 am
allsierra123
« Reply #3 on: April 17, 2009, 10:09:49 am »
mine has the idler pulley on th water pump.
Reply #4April 17, 2009, 10:11:31 am
flapjack
  • 283
« Reply #4 on: April 17, 2009, 10:11:31 am »
really? wow, in that case, can I have a picture of your setup? :)
what is that from?
signature
Reply #5April 17, 2009, 10:15:59 am
blackdogvan
  • 574
« Reply #5 on: April 17, 2009, 10:15:59 am »
I believe its the same as tdi, someone will correct me if i'm wrong...
If thats not close to your setup this PDF from VW should have a setup that matches yours.
http://www.haywood-sullivan.com/vanagon/TDI/vw_diesel_pulleys_de.pdf
1991 Vanagon 1.9 mTDI
Reply #6April 17, 2009, 11:03:21 am
allsierra123
« Reply #6 on: April 17, 2009, 11:03:21 am »
well the guy I bought the engine from told me he set it up for that. maybe he didnt do it right it does look similar though to that PDF except the power steering pump was the only belt running on the vw belt. The rest has the serpentine pulley's on them. its from a 96 aaz engine.
Reply #7April 17, 2009, 11:04:18 am
allsierra123
« Reply #7 on: April 17, 2009, 11:04:18 am »
I may have to take the AC off and worry about it at a later date.
Reply #8April 18, 2009, 03:58:22 pm
allsierra123
« Reply #8 on: April 18, 2009, 03:58:22 pm »
Ok today I removed the AC going to have to work out a setup later to use my ac without the power steering pump
Reply #9April 29, 2009, 08:28:45 pm
allsierra123
« Reply #9 on: April 29, 2009, 08:28:45 pm »
It actually has PS but its been Inop for a while do to the many many leaks from the front to back. The more I dig into this van the more I think someone ran it through some very rough terrain.
Reply #10April 29, 2009, 09:39:02 pm
allsierra123
« Reply #10 on: April 29, 2009, 09:39:02 pm »
Well Im gonna file nugget of info away. Im up to my rear end in wiring and hoses right now. But Im starting to see the light at the end of the tunnel with this conversion.
