Author Topic: Could I have a bad injector barb?  (Read 6709 times)
April 15, 2009, 08:31:54 am
katakura silk
  • 92
« on: April 15, 2009, 08:31:54 am »
I just replaced my 1.5L head with a rebuilt one :D  The car is running like a champ, but I now have this annoying issue. One and only one injector is leaking from the return line. I have replaced the hose about 4 times! It just keeps coming back.
Could it be a bad barb? Fuel is leaking down and settling on my HG (the notch tab that sticks out)
I want to conserve fuel(even though it just leaks a little)
It also drives me crazy if the car is leaking anything :evil:
The injectors are rebuilt.
Thanks! -Joseph
1979 Diesel Rabbit L - 60k :)
1982 Diesel Caddy (RIP) now 1.8L Gasser
1998 Passat Wagon
Reply #1April 15, 2009, 01:53:26 pm
spencebm
  • 686
« Reply #1 on: April 15, 2009, 01:53:26 pm »
put a little clamp on those lines that are leaking any fuel or you could try some silicone?  smaller lines?  don't send me text messages!  text messages are for little girls... :shock:
Ben Spencer
Reply #2April 15, 2009, 03:45:24 pm
katakura silk
  • 92
« Reply #2 on: April 15, 2009, 03:45:24 pm »
Go put Veggi oil in your tank
Im just going to try one old injector. See what happens then...
1998 Passat Wagon
Reply #3April 15, 2009, 04:26:38 pm
spencebm
  • 686
« Reply #3 on: April 15, 2009, 04:26:38 pm »
love you
Ben Spencer
Reply #4April 15, 2009, 11:33:25 pm
Op-Ivy
  • 513
« Reply #4 on: April 15, 2009, 11:33:25 pm »
Put a clamp or zip tie on it. It should stop it. If not, then you very well may have a problem with your barb.
I wouldn't suggest putting silicone on it. Not only would it probably corrode quickly but it might get a little messy. :P
Reply #5April 16, 2009, 04:14:55 am
  • 3468
    • McScrubbins Body Wash
« Reply #5 on: April 16, 2009, 04:14:55 am »
Quote from: "Op-Ivy"
and that stuff stinks!
Zip tie to the rescue. My whole engine is being held together with zip ties. Screw arp studs.
Reply #6April 16, 2009, 06:50:01 am
katakura silk
  • 92
« Reply #6 on: April 16, 2009, 06:50:01 am »
Thanks for the help.
I just want to punch this injector in the face :twisted:
I will give the zip tie a chance, maybe a smaller diameter hose, but the hose im using is already pretty small....
(it seems to make a good seal, because it hard to pull the hose off to replace...)
1998 Passat Wagon
Reply #7April 16, 2009, 04:56:26 pm
ktzdsl
  • 73
« Reply #7 on: April 16, 2009, 04:56:26 pm »
I just finished a test to see if my injector was leaking or not. I was going to replace the injector to see if that eliminated the leak. However, as I was re-connecting the lines to the injector; I noticed that the line was NOT matching up with the injector. Not barely but by 1/2 of the diameter of the line. So, I loosened all of the lines, and the little rubber clamps and the lines at the pump, shifted lines around until the match-up was improved. Since I was also changing the oil, I am about to complete that job and then test the injector for leaking again. I will post back with the results. The way it was before, the leak appeared to becoming from the line to injector connection.
DFW area Texas
1982 1.6L NA diesel pickup
Reply #8April 17, 2009, 10:05:49 pm
katakura silk
  • 92
« Reply #8 on: April 17, 2009, 10:05:49 pm »
UPDATE:
I stopped the leak!
But...there is a problem. I used one of my old injectors. I can tell its not up to par, the car seems just a tad bit off to accelerate. Just a little shaky/rough( car idles fine & starts fine)
It was a bad barb that caused the return line to leak.
Im going to have to make due with the one bad injector for a few days...Will this do damage?
Or will i just have to deal with the fact that the car was running like a dream and now it is just off enough to be annoying?
1998 Passat Wagon
Reply #9April 18, 2009, 12:04:41 am
« Reply #9 on: April 18, 2009, 12:04:41 am »
depends on how bad your "bad" injector is :P
Reply #10April 18, 2009, 07:57:41 am
katakura silk
  • 92
« Reply #10 on: April 18, 2009, 07:57:41 am »
Not too bad...
1998 Passat Wagon
Reply #11April 18, 2009, 08:42:08 am
« Reply #11 on: April 18, 2009, 08:42:08 am »
well it ran fine before right? lol i think it will be fine for a while. as long as it still has a normal spray pattern. :)
Reply #12April 18, 2009, 03:09:57 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
« Reply #12 on: April 18, 2009, 03:09:57 pm »
Take the injectors apart and swap nozzles
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #13April 19, 2009, 01:01:22 am
Op-Ivy
  • 513
« Reply #13 on: April 19, 2009, 01:01:22 am »
Quote from: "jettabrendan"
You would have to pop test it one way or another. The injector could be "bad" for two reasons. Poor spray pattern and different breaking pressure.
Reply #14April 19, 2009, 07:51:18 am
katakura silk
  • 92
« Reply #14 on: April 19, 2009, 07:51:18 am »
Im pretty sure the old one I put in must have a different spray pattern/breaking pressure. The car idles fine, but under a load it just off a little. The power is shaky/loud... Maybe I will post a video.(I just got a new video camera) That would be fun.
Can you embed YouTube videos?
1998 Passat Wagon
