Author Topic: revs limited in lower gears  (Read 3453 times)
April 12, 2009, 07:50:39 pm
thomcat
  • 20
« on: April 12, 2009, 07:50:39 pm »
I finaly have my first rabbit diesel on the road, and a new prob crept up tonight. We were riding around town racking up a few miles( aprox 150 since complete rebuild).  I got the urge to let loose all that wonderful 1.6 na horsepower :shock:  and as I gained some rpm(est 3000 to 3500) the engine  shut down  like the fuel was shut off. I let off the throttle and it would go again, but not rev higher, same result in all the lower gears. Fifth I didnt have the opportunity to try.  I do know my alternator belt is loose ;could the w wire cause  the fuel shut off to engage on the bosch pump ?
 It was fine untill tonight.
Thom
Reply #1April 13, 2009, 01:03:04 am
  • 3468
    • McScrubbins Body Wash
« Reply #1 on: April 13, 2009, 01:03:04 am »
the fuel shut off solenoid uses 12v to stay OPEN. No power = closed. So long as it's connected to the battery and the battery isn't dead it shouldn't shut off.
Check the wire to the solenoid. It may be deteriorating.
Reply #2April 13, 2009, 05:40:19 am
thomcat
  • 20
« Reply #2 on: April 13, 2009, 05:40:19 am »
Is there anything in the circuit with the shut off soleniod that could  trigger it? ie a rpm limiter , up shift light, or something of that nature? It ran fine untill last night then the "shut down point" was at aprox the same rpm in first three gears.  I could hold it to the floor indefinatly in 5th and havent had a problem so im guessing the fuel filter is fine . I am hoever going to change it today on principle.
Reply #3April 13, 2009, 06:09:02 am
thomcat
  • 20
GOT IT !!!
« Reply #3 on: April 13, 2009, 06:09:02 am »
I found it ! My apologies for  wasting everyones time. the wire to the shut off soleniod worked itself loose and I missed it in the dark. All is well now.
and thanks for your attention
Thom
