Author Topic: 1.6 TD mods  (Read 6521 times)
August 29, 2005, 10:35:45 pm
optiks
  • 31
1.6 TD mods
« on: August 29, 2005, 10:35:45 pm »
hey guys i know there is a list of mods to do to a 1,6 TD. I did the one to my 1.9td and now my friend is looking for some instructions on how to tune his pump for some performance
my car
Reply #1August 30, 2005, 01:25:40 am
  • 1156
    • Malone Tuning Ltd.
Re: 1.6 TD mods
« Reply #1 on: August 30, 2005, 01:25:40 am »
1) http://www.vwdiesel.net/phpBB/viewtopic.php?t=579
Yes, it's a 1.9L, but same thing applies to 1.6TDs. Disregard the first image; skip straight to "ADJUSTMENT OF THE FUELING", second image.
2) Remove boost pin and spring (you've already done this before... it's also easier on a 1.6TD), look inside and you'll see a starwheel. Turn the starwheel clockwise a couple times with your fingers and it'll go lower. Reinstall spring and boost pin. This lets the boost pin sit lower, so more fuel will be injected earlier. It will easily cause more exhaust smoke though. I got tired of it and raised the starwheel back to near-factory location. Not a necessary mod.
3) Rotate the boost pin to the aggressive side. This results in slightly more fuel under boost.
The rest is more challenging:
4) Set pump timing to 1.05mm. Easy to do, but you'll need to find a shop that has the pump timing gauge.
5) Remove RPM governor.
http://www.vwdiesel.net/phpBB/viewtopic.php?t=157
Stock TDs start cutting off fuel after approx. 2,800 RPM. Eliminating the governor will improve fueling above 2,800 RPM and allow the engine to continue running past 4,500 RPM. A tachometer is MANDATORY. Hope your friend won't overrev!
6) Still not enough fuel? GTD fuel injector nozzles. Your friend can buy nozzles already installed on injectors with a core charge, which'll make the job easier (just swap injectors).
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #2August 30, 2005, 08:03:56 am
optiks
  • 31
1.6 TD mods
« Reply #2 on: August 30, 2005, 08:03:56 am »
your the man!
my car runs finally
3"mandrel exhaust, 2,5" mandrel downpipe, fmic, kkk k24 and 26psi
damn it moves  :D
Reply #3August 30, 2005, 09:26:15 am
kynetx
  • 24
1.6 TD mods
« Reply #3 on: August 30, 2005, 09:26:15 am »
Did you have trouble getting the 3 inch exhaust in without rattles?
Reply #4August 30, 2005, 10:00:17 am
optiks
  • 31
1.6 TD mods
« Reply #4 on: August 30, 2005, 10:00:17 am »
rattles when backing up but i am also lowered over 3" on full coilovers
Reply #5August 30, 2005, 12:43:56 pm
entuzijast
  • 73
    • http://www.geof.hr/~imalovic
1.6 TD mods
« Reply #5 on: August 30, 2005, 12:43:56 pm »
I also have a question....
I am not so good in mechanic (I have made the easy pump mods), but i want to put a 1.9TD head gasket. But the bore is not the same, 1.6 is 76,5mm and 1.9 is 79,5mm.
So how do you put a 1.9 head gasket?
I have looked on forum, but didn't find it.......
Excuse me on my bad English
