Author Topic: oil dripping from exhaust  (Read 2084 times)
April 09, 2009, 10:39:32 pm
windsnob54
  • 15
« on: April 09, 2009, 10:39:32 pm »
I have a 1.9td in a westy with a 2.5" straight pipe off the turbo. It is dripping oil out the tail pipe. Is this a sure sign of a turbo rebuild or is this perhaps something less serious?
thanks
M
Reply #1April 10, 2009, 09:45:32 am
« Reply #1 on: April 10, 2009, 09:45:32 am »
sounds like your turbo broke its last leg. if you have oil coming out the exhaust, you better hope its just the turbo. cause if there were that much oil coming from the engine, it would probably mean you have worse problems then turbo seal failure. but yea, sounds like its time for a rebuild.
Reply #2April 10, 2009, 05:53:51 pm
Golf/Jetta
  • 102
« Reply #2 on: April 10, 2009, 05:53:51 pm »
could also be valve stem seals
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
Reply #3April 10, 2009, 05:58:59 pm
hamradio
  • 282
« Reply #3 on: April 10, 2009, 05:58:59 pm »
Also take into consideration oil drain, if you just installed the turbo, started it up, and found oil leaking...your drain may be too restrictive.
