Turbo 1.5 Samurai
Topic: Turbo 1.5 Samurai (Read 3261 times)
April 04, 2009, 10:06:41 pm
UnderPSI
Turbo 1.5 Samurai
April 04, 2009, 10:06:41 pm »
Got my turbo on, it's a little KO3. Runs great except for the crankcase is getting more pressure than my cylinders. Holy tons of blowby.
Suzuki Samurai 1.6
April 05, 2009, 03:36:29 am
Dr. Diesel
Authorized Vendor
Turbo 1.5 Samurai
April 05, 2009, 03:36:29 am »
those old 1.5L engines were bad for that. They had to make up a funky oil seperator system to reduce (not prevent!) oil runaway.
My old 1.5L rabbit (non-turbo) had better 5th gear acceleration in runaway with the key off, than normally with the pedal to the floor.
April 05, 2009, 07:07:15 am
Baixo
Turbo 1.5 Samurai
April 05, 2009, 07:07:15 am »
lets see some vidoes and pics
April 05, 2009, 09:09:05 am
Turbo 1.5 Samurai
April 05, 2009, 09:09:05 am »
on my old 1.6 it helped alot when i added an extra breather to the front of the block where the vacuum pump drains oil back in i just connected it to the hose up top at the valve cover, all my oil blow by and run away problems were solved.
April 05, 2009, 09:16:19 am
UnderPSI
Turbo 1.5 Samurai
April 05, 2009, 09:16:19 am »
I have 3 crankcase breathers, it helps, but still spits oil out. I'll see if I can get some pics.
Suzuki Samurai 1.6
April 05, 2009, 10:15:58 am
Turbo 1.5 Samurai
April 05, 2009, 10:15:58 am »
i have a crankcase breather and a valve cover breather. and they are both running to a oil recovery can. and then the blow by runs right into the intake about 2 inches above the turbo. my engine likes to blow oil out the dip stick hole. its a really old block and the stick doesnt have a tube to go in or nothin, just sits in the block. and it doesnt seal very good.
April 05, 2009, 06:54:00 pm
UnderPSI
Turbo 1.5 Samurai
April 05, 2009, 06:54:00 pm »
Suzuki Samurai 1.6
April 06, 2009, 08:57:54 am
Turbo 1.5 Samurai
April 06, 2009, 08:57:54 am »
That's some high tech tubing ya got going on there :lol:
Just pokin fun.
April 06, 2009, 03:43:52 pm
UnderPSI
Turbo 1.5 Samurai
April 06, 2009, 03:43:52 pm »
exhaust pipe and radiator hose, it's the cheap way. I don't care about looks, just if it works.
Suzuki Samurai 1.6
April 07, 2009, 03:06:37 am
Turbo 1.5 Samurai
April 07, 2009, 03:06:37 am »
Quote from: "UnderPSI"
damn rights!
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
April 07, 2009, 05:12:24 am
Baixo
Turbo 1.5 Samurai
April 07, 2009, 05:12:24 am »
haha, that samurai looks sweet!!
any video's of it running, driving and boosting??
Reply #11
April 07, 2009, 06:35:20 pm
UnderPSI
Turbo 1.5 Samurai
Reply #11 on:
April 07, 2009, 06:35:20 pm »
I don't have any videos, it is a lot better than the stock 1.3 that came out of it.
Suzuki Samurai 1.6
Turbo 1.5 Samurai
