Author Topic: back to square 1  (Read 2534 times)
April 04, 2009, 07:41:13 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
back to square 1
« on: April 04, 2009, 07:41:13 pm »
so got my car running beautifully... BUT coolant is still coming out of the expansion tank. New headgasket was put on and everything so idk. The only thing i think it could be is the thermostat is toast and its stuck shut? if it was anything more serious like a crack it would be instant when i start it? it takes about 15-20 min untill the coolant comes over the top of the tank. it starts and runs like new.
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #1April 04, 2009, 07:53:24 pm
jettabrendan
  • 198
back to square 1
« Reply #1 on: April 04, 2009, 07:53:24 pm »
or the water pump?
Reply #2April 04, 2009, 08:02:10 pm
Kantdrivefast
  • 196
back to square 1
« Reply #2 on: April 04, 2009, 08:02:10 pm »
Or you didn't bleed all the air out of the system...
Reply #3April 04, 2009, 08:05:29 pm
back to square 1
« Reply #3 on: April 04, 2009, 08:05:29 pm »
or the coolant cap is no longer working properly. Have you pressure tested it?
Reply #4April 04, 2009, 08:14:02 pm
jettabrendan
  • 198
back to square 1
« Reply #4 on: April 04, 2009, 08:14:02 pm »
this is why it got pulled off the road, it was doing this when diagnosed with a bad head gasket.. so i changed it and its doing the same thing. the bottom rad hose was cold, top one gets very hot, so it could very well be an air bubble. Im gunna buy a new thermostat anyways, flush and refill it and buy a new cap, if that does not solve my problem, anyone wanna buy a 91 turbo jetta? LOL
Reply #5April 05, 2009, 04:17:39 am
back to square 1
« Reply #5 on: April 05, 2009, 04:17:39 am »
drill a tiny hole in the thermostat before you put it in...1/16" or 1/8" no need to go bigger and it will help the air get out. It also won't flow enough to overly cool the engine and the stat will still work.
Reply #6April 05, 2009, 09:15:08 pm
jettabrendan
  • 198
back to square 1
« Reply #6 on: April 05, 2009, 09:15:08 pm »
FIXED!! i changed the thermostat, flushed, buddy noticed the pressure cap was missing its o-ring. car holds coolant. it runs pretty good but i think the timing is a bit retarded. It dosent idle like my 92, slow kind of lopey idle.
Reply #7April 09, 2009, 12:36:06 pm
jettabrendan
  • 198
back to square 1
« Reply #7 on: April 09, 2009, 12:36:06 pm »
bump, now my fan wont turn on.. but here she is, finally found my camera..
Reply #8April 09, 2009, 01:11:53 pm
back to square 1
« Reply #8 on: April 09, 2009, 01:11:53 pm »
try the sensor in the rad. jump the 2 wires together. if the fan turns on, thats the prob. if the fan dont turn on, start digging in the wiring. and you could also run a wire from the batt to it just to see that the fan isnt your problem.
Reply #9April 09, 2009, 01:15:15 pm
jettabrendan
  • 198
back to square 1
« Reply #9 on: April 09, 2009, 01:15:15 pm »
im pretty sure its the resistor but i could be wrong. If i take a wire and go from + on the batt to the top wire on the resistor, it turns on but it stays on untill i unhook the wire.
