Who is running a Turbo Diesel or TDI Scirocco?
Topic: Who is running a Turbo Diesel or TDI Scirocco? (Read 3773 times)
April 04, 2009, 07:19:12 pm
subsonic
April 04, 2009, 07:19:12 pm »
I have seen posts by Lord V. , TedV and MJF. Anybody else. Sounds like a very cool setup if you can get an early lightweight Scirocco. I like the early mk1's from the late 70's although the later ones are still pretty cool.
I would like to hear about your cars and how you worked out the swaps. What you did for tranny choices / axles etc. Where did you mount your IC? TedV, Did you have to do anything to stiffen up the body for the autocrossing? Anyone running a LSD? 0-60mph times / 1/4mile times etc. How do you think they handle compared to Golf's and Jetta's? Have you run against other modded gas Scirocco's?
April 04, 2009, 11:04:09 pm
sawedoffgolf
April 04, 2009, 11:04:09 pm »
me and my friend were actually talking a few hours ago about doing this haha.
April 05, 2009, 01:21:51 pm
MJF
April 05, 2009, 01:21:51 pm »
02A Passat tranny. Rear mount from Passat, front custom. Passat clutch cable setup and cable shifter. Custom driveshafts needed. Made a reinforcent bar to prevent cracking crossmember.
Intercooler (~50x29cm) is located in front of mk2 td radiator.
Never tried 0-60, but it was ~6 seconds. Best 1/4 14,5/166kmh. Body ī74 TS, weighed 960kg. Engine 1,7TD, 223hp/350nm @ dyno.
Pic
Video against gasser-mk1
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
April 05, 2009, 01:42:58 pm
subsonic
April 05, 2009, 01:42:58 pm »
Was the 02A passat tranny a diesel unit? CTN? What did you need to do for your axles? Do you have any pictures of your build up? What are you running for a turbo on the 1.7? What have you done to the engine for mods? Any sort of porting on the head?
April 05, 2009, 02:01:57 pm
MJF
April 05, 2009, 02:01:57 pm »
First tranny was originally behind aaz, rivets from differential broke. Second is from 2,0 gasser. Donīt remember codes. Axles needed to cut shorter and 100mm inner joints installed. Garrett GT2359V @ 2,0bar boost. Engine specs are somewhere here, it threw a rod.
Not much pictures
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
April 05, 2009, 02:30:53 pm
subsonic
April 05, 2009, 02:30:53 pm »
I was looking at one of your engine bay photo's. Is your intake made from a volvo 24d? It almost looks like a dual plenum setup.
This photo.
http://www.kotinet.com/matti.farm/Scirocco/IMG_2655.jpg
April 05, 2009, 02:33:02 pm
MJF
April 05, 2009, 02:33:02 pm »
Quote from: "subsonic"
Yep, from Volvo. Not dual plenum, just cut 2 cylinders away.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
April 05, 2009, 02:59:19 pm
subsonic
April 05, 2009, 02:59:19 pm »
I have seen done before, you did a very nice job on it.
Can you tell me about how you bent your connecting rod? Was it one of your carillo rods or a stock one?
April 06, 2009, 01:24:14 am
MJF
April 06, 2009, 01:24:14 am »
It was Carrillo. Donīt know exactly what happened, but I believe that rod pin end was too narrow and allowed pin to flex.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
April 14, 2009, 05:07:38 pm
April 14, 2009, 05:07:38 pm »
just a note, if you use scirocco 16v spindles or later cabriolet spindles, and then use 100mm 16v or cabby axles then no axle mods are needed for an 02a
April 15, 2009, 03:11:19 am
Patrick
April 15, 2009, 03:11:19 am »
Won't the AAz bolt to the existing 020? Irealize it won't like the 200+ horsepower he's got, but they stand up fine to a more moderate build... I'm going to look at 2 cars this weekend, a '78 and an '81 that have been garaged for a few years. They're supposed to be fairly solid, and I have an AAZ that needs a home....
