Tranny
Topic: Tranny (Read 2401 times)
April 02, 2009, 12:05:30 pm
dokarex
Tranny
April 02, 2009, 12:05:30 pm »
What would happen if I go from an ABF tranny to a DU tranny in my Vanagon?
091/1 091/1 091/1
ID character DU
For engine 1.9L
Year < 84.7
1. gear3.78
2. gear 2.06
3. gear 1.23
4. gear 0.85
Revers 3.67
Transaxle
4.86
ABF091/1 091/1 091/1
ID character ABF
For engine 1.6L
Fuel Diesel
Year 84.8
1. gear 3.78
2. gear 2.06
3. gear 1.23
4. gear 0.85
Revers 3.67
Transaxle
5.83
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
April 02, 2009, 12:06:42 pm
Tranny
April 02, 2009, 12:06:42 pm »
EDIT!!
I had read it backwards as to which trans you were changing from.
Using a 205/70r14 tire;
The top trans would have your engine spinning @ 3000 rpm @ 54 mph.
The lower trans would be 3000 rpm and 45 mph.
April 02, 2009, 12:08:31 pm
dokarex
Tranny
April 02, 2009, 12:08:31 pm »
Wouldn't the rpms be lower with the DU instead of the ABF along with a higher top end?
B6200 Kubota Diesel
16ft Sunray 85HP
April 02, 2009, 12:10:58 pm
Tranny
April 02, 2009, 12:10:58 pm »
Quote from: "dokarex"
[size=0]
No,
In gears the higher # is lower gearing. So a 5.89 Ring and pinion would spin the engine faster than a Ring and pinion of say 4.89.
The lower the # the slower the engine wi
ll spin.[/size]
Oh hell!!
Yes I read that backwards!
The DU will have lower RPM's.
April 02, 2009, 12:40:25 pm
Tranny
April 02, 2009, 12:40:25 pm »
I did exactly that;it's a 5 speed, but with the same 5th and R&P. At 3600 rpms,i was going 88 kph. When i changed it i can go 102 with stock size tires, and 107 with the 195/65/16's in summer.
April 02, 2009, 01:51:19 pm
dokarex
Tranny
April 02, 2009, 01:51:19 pm »
You put in a 5 speed or are you telling me the DU is a 5 speed.
What is your top speed 102 with stock?
I already top out at 102 with the ABF and stock tires(1.9TD)
B6200 Kubota Diesel
16ft Sunray 85HP
April 02, 2009, 02:52:19 pm
Tranny
April 02, 2009, 02:52:19 pm »
It isn't a DU .It's a syncro trans and diff but without the 4wd output. It's just the ratios are the same as a DU.
The speeds i mention aren't top speed ,but cruising speeds.Top spedd befroe was maybe 110. I haven't even tried with the engine i have now, maybe 125 if i plug my ears and don't look at the tach.
Tranny
