Author Topic: a Few ??  (Read 12385 times)
April 01, 2009, 09:30:29 pm
a Few ??
« on: April 01, 2009, 09:30:29 pm »
Ok so i switched to some crap summer tires to preserve my winters today.. i got them over the winter so i never used them.. the right rear makes an odd thumping sound that increases with speed.. but is dampened by applying the e-brake.. ALSO i stripped two and half of the four lug bolts.. i thought this might be the problem.. but if i put the other tire or a differnet tire on.. it doesn't make the sound..
AND my steering has gotten really hard to turn while going slow.. whats up with that?
Reply #1April 01, 2009, 11:27:37 pm
  • 3468
    • McScrubbins Body Wash
a Few ??
« Reply #1 on: April 01, 2009, 11:27:37 pm »
pump them suckas up for the steering.
the rear tire may be damaged. Have a bulge on the inside. or be flat....
Dang man... you stripped the BOLTS or the drum?
Edit: btw, Jer, do you drive that thing for comic relief or for the cheers from the crowd cheering you to your iminent death just like a budding dare devil...
Reply #2April 02, 2009, 12:52:14 am
Turbinepowered
  • 1206
a Few ??
« Reply #2 on: April 02, 2009, 12:52:14 am »
Check the balance on your thumper tire. Speed-dependent sounds that you dampen with braking, I've found, usually mean something's out of balance. Especially if it goes away if you swap it for a different tire.
Reply #3April 02, 2009, 01:00:40 am
  • 3468
a Few ??
« Reply #3 on: April 02, 2009, 01:00:40 am »
wow i just noticed you still have snow. it's 15 degrees here. and sunny :P (well... it rained today but it's been sunny)
Reply #4April 02, 2009, 07:10:42 am
a Few ??
« Reply #4 on: April 02, 2009, 07:10:42 am »
I figured steering was because of psi... I thought maybe the rear had a plug i missed before i put them on.. so i checked it out.. no plug.. must be be out of balance..  and no bulge on the inside, what would this cause?
I stripped the drum apparently :P when i took the bolts out they had filled in threads :( gotta go down to the locla parts store and get me a new drum :P
Btw Ed. Lol I drive it because it is the most reliable vehicle i have ever had the pleasure to sit in :) It's a real head turner :P
Yeah the out of balance would make sense.. if it were wiggling the drum around.. applying the brakes and centering the drum would dampen the sound... I see grass hopppah
Ps. Is my car really THAT ugly Ed? lol
Reply #5April 02, 2009, 05:44:35 pm
  • 3468
a Few ??
« Reply #5 on: April 02, 2009, 05:44:35 pm »
It was supposed to be funny because mine is so hideous i refuse to take pictures of it :P
Reply #6April 02, 2009, 06:06:42 pm
diesel smoke
  • 209
a Few ??
« Reply #6 on: April 02, 2009, 06:06:42 pm »
I'd roll it.  :wink:
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #7April 02, 2009, 06:29:18 pm
a Few ??
« Reply #7 on: April 02, 2009, 06:29:18 pm »
Quote from: "diesel smoke"
I'd roll it.  :wink:
haha, Decent. your probably the first to say that about my car :P
Most people ask me if its safe.. lmao
Reply #8April 02, 2009, 06:53:36 pm
diesel smoke
  • 209
a Few ??
« Reply #8 on: April 02, 2009, 06:53:36 pm »
:lol: I'd roll that before a newer ricer. It probably wouldn't fall to pieces on the gravel roads I drive on. Japanese cars die fast up here. :twisted:
'99.5 Bora TDI
'88 Fox Coupe
'85 Mercedes 300SD
Reply #9April 02, 2009, 07:04:58 pm
a Few ??
« Reply #9 on: April 02, 2009, 07:04:58 pm »
Quote from: "8v-of-fury"
That's usually the first thing people say about my car too.
I have some extra 180mm drums if you want them. I think the local garage charges $35 to turn them
Reply #10April 02, 2009, 07:07:38 pm
a Few ??
« Reply #10 on: April 02, 2009, 07:07:38 pm »
Are any of them in good enough shape to not need the turning? lmao
35.. i dunno might be near the same to buy new.. and i wouldnt have to drive all the way down to scarborouhg ;P
Reply #11April 02, 2009, 07:13:59 pm
a Few ??
« Reply #11 on: April 02, 2009, 07:13:59 pm »
Dirt roads where I live in The Great White North are pretty much an everyday occurrence :P Lowered cars don't fair well here either.. lol
chipped skirts and plastic bumpers.. Only plastic i have on the exterior is the rear bumper :P  and if it gets cracked.. who cares.. just add to the look of my car :P
Reply #12April 02, 2009, 07:16:22 pm
  • 3468
a Few ??
« Reply #12 on: April 02, 2009, 07:16:22 pm »
:oops: my jetta is lowered :oops:  i live in the GWN
I should finally take some pics of mine shouldn't i...
Reply #13April 02, 2009, 07:18:12 pm
a Few ??
« Reply #13 on: April 02, 2009, 07:18:12 pm »
B.C actually is a province that cares about its roads :P Try GWN Ontario! lmao..
ROUGH stuff up here man. How much is it lowered Ed? Why don't you post us a pic of that beast? lol im sure its better looking then mine lol
Reply #14April 02, 2009, 07:22:38 pm
  • 3468
a Few ??
« Reply #14 on: April 02, 2009, 07:22:38 pm »
only the rear is lowered :oops: im waiting on  commuter boy to do the front struts as i don't have the right tools.
I'll go take some ^.^ I'll see if i can't get a friend over later to snap a shot of me ROASTING the tires...
Also, in BC it rarely gets cold enough to damage the roads. this year there was a tad of road damage.
