Lift Pump
Topic: Lift Pump (Read 1907 times)
April 01, 2009, 03:17:57 pm
Kantdrive55
Lift Pump
April 01, 2009, 03:17:57 pm »
What lift pump are you using on your car? I have a 93 Jetta with a mildly modified 1.9 and want to put a lift pump on it. I am thinking it should be around 6-8psi?
Thanks
1993 TD Jetta
Cold air intake,pump tweaked,2.5" exhaust and more to come.
April 01, 2009, 03:41:36 pm
Lift Pump
April 01, 2009, 03:41:36 pm »
get a facet solid state pump. the 4-7 psi versions are perfect. i've one on my car and it really helps, but isn't really necessary with a good pump. it will help with performance mods, and virtually eliminate pump cavitation (for whatever reason)
Lift Pump
