Author Topic: Make your own downpipe for MK1 A1 chassis - PIC HEAVY!  (Read 7365 times)
March 30, 2009, 08:37:10 am
regcheeseman
  • 714
« on: March 30, 2009, 08:37:10 am »
Start off with a 180 mandrel bend, they typically come with one end longer than the other
Cut off the long leg at a slight angle, you want the pipe to exit the turbo at an angle to achieve the clearance required
Weld on a flange – you can use the original one. With all the welding on this job, you need to do a lot of trial fitting to get it right, eye the job up, tack and check it. Oh watch out for the manifold studs, you need to be able to get a spanner on them!
Cut at 45 ish degree and rotate the cut off section through about 180 degrees and weld it back on – you need a bit of a dog leg, so check and tack up first.
Next step is fitting the 90 deg bend to return the pipe to point towards back of car – you may need to fit a small section of straight or angle the pipe slightly to get the pipe in the right place – I aim for the side of gear selector tunnel.
There, pretty much done – I add a 100mm section of straight then a flexi then another 100mm section. It’s up to you.
Here are a few pics of my first pipe fitted up to engine so you know roughly how it should look….and some of my later ones….
Reply #1March 30, 2009, 12:43:34 pm
« Reply #1 on: March 30, 2009, 12:43:34 pm »
Wow!!!  Thanks for that, very nice DIY!
I'm guessing a Mk2 will be a very similar design?  I will have to tackle this sooner than later- you just made it look much easier than I had first thought.
What sort of welder did you use?  Looks like TIG.
Great stuff, thanks for sharing.
Reply #2March 30, 2009, 03:29:17 pm
regcheeseman
  • 714
« Reply #2 on: March 30, 2009, 03:29:17 pm »
yep all TIG.
I did have access to free stainless and a TIG, about the only perk of that particular job - but I've moved on. Would love a TIG at home.....
Reply #3March 30, 2009, 03:56:48 pm
rallydiesel
  • 1880
« Reply #3 on: March 30, 2009, 03:56:48 pm »
This is why this site is so great!
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4March 31, 2009, 02:28:40 am
regcheeseman
  • 714
« Reply #4 on: March 31, 2009, 02:28:40 am »
would it be of use as a sticky or FAQ?
Reply #5March 31, 2009, 04:49:03 am
1outof5
« Reply #5 on: March 31, 2009, 04:49:03 am »
Thanks Reg ! Whish I had your skills to do it myself.
Great stuff (that includes the diesel tach/rev counter mod)
Reply #6March 31, 2009, 06:24:48 am
« Reply #6 on: March 31, 2009, 06:24:48 am »
Quote from: "regcheeseman"
Ya, i'd say so, especially since nobody is making downpipes commercially anymore.
Reply #7April 01, 2009, 08:02:15 am
FoXBoXRaCiNG
  • 92
« Reply #7 on: April 01, 2009, 08:02:15 am »
Props  :D
My cat has A.D.D :(
Reply #8April 01, 2009, 05:00:15 pm
Dr. Diesel
  • 1341
« Reply #8 on: April 01, 2009, 05:00:15 pm »
Make sure you brace that badboy against the engine block, triangulated-like. Nice job!
Reply #9April 01, 2009, 05:06:20 pm
« Reply #9 on: April 01, 2009, 05:06:20 pm »
Quote from: "lord_verminaard"
false techtonics tuning makes them, but damn they are 345 now,  might as well have a shop do it for you at that cost.
Reply #10April 01, 2009, 07:58:50 pm
truckinwagen
  • 1895
« Reply #10 on: April 01, 2009, 07:58:50 pm »
hell, I have built a couple in the dorm parking lot with a 110 arc welder and an angle grinder with a cutoff wheel.
they didn't look as nice as these (mostly due to the fact that an arc weld on thin steel looks like poop no matter how good it is) but paying any more than $150 is just crazy when you can buy a little welder and the materials for less than $200(and then you have a welder to fix and build anything else you might want later)
super good looking downpipes by the way, much nicer than the ones I built.
83 Opel Kadett Diesel
Reply #11June 30, 2011, 12:25:28 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
Re: Make your own downpipe for MK1 A1 chassis - PIC HEAVY!
« Reply #11 on: June 30, 2011, 12:25:28 pm »
Will this Work with 2.5" pipe?
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #12June 30, 2011, 12:39:23 pm
« Reply #12 on: June 30, 2011, 12:39:23 pm »
mk2 will have 2 more bends to clear the steering rack since its mounted on the subframe, instead of on the unibody..
Reply #13June 30, 2011, 11:53:39 pm
  • 2932
« Reply #13 on: June 30, 2011, 11:53:39 pm »
That looks great but I like the idea of supporting it to the block,
 I use the early 4 into 2 into 1 downpipe supports,
  that bolt to the bock and trany,
  just before the flex.
