Author Topic: FS MK1 Parts and Shell  (Read 3577 times)
March 26, 2009, 06:56:43 pm
Jolly1977
  • 43
« on: March 26, 2009, 06:56:43 pm »
I have a ’81 VW Rabbit shell/body (2-door) that has been stripped of most of its parts.  All that is left is the shell, steering components, suspension, and associated undercarriage parts.  I’m selling the shell as-is in one piece for $150, or make me an offer.
If no one is interested in the shell as one piece I will part the shell out.  Bring your sawzall and torches and take what ever you want for $1 per pound.
I also have about 80% of the parts leftover that never got used.  I'm looking to unload everything that I have (prices not including shipping);
Engine and trans
4 spd transmission ($40)
4 spd shift rod ($5)
Flywheel and clutch assembly ($20)
Throttle cable ($5)
Clutch cable ($5)
Speedometer cable ($5)
Engine block ($25)
Engine mounts ($5 ea)
Oil pump ($15)
Front oil seal carrier ($5)
Rear oil seal carrier ($5)
Main bearings and caps ($25)
Piston wrist pins and circlips ($10)
Connecting rods and bearings ($25)
Injectors ($30)
Alternator ($10)
Alternator bracket ($5)
Starter, brand new ($35)
Fuel sending unit ($5)
Fuel filter housing ($5)
Exhaust manifold ($10)
Water pump ($10)
Valve cover ($5)
Tension pulley ($5)
Cam sprocket ($5)
Oil filter flange ($5)
Crankshaft sprocket ($5)
Complete wiring harness and fuse box ($25)
Master cylinder ($5)
Radiator ($35)
Interior
Front seats, mint cond ($25 ea)
Rear seat, mind cond ($25)
Gauge cluster ($25)
Ignition/steering lock cylinder ($10)
Interior dash panels (make offer)
Interior duct work (make offer)
Pedals ($5)
Blower motor, heater core, duct housing ($25)
Rear defrost switch ($5)
Interior door trim panels ($15 both)
Front speakers and covers ($5)
Body
Doors, 2 door car ($25)
Hood ($20)
Rear hatch ($25)
Front and rear bumpers ($15 ea)
Windshield wiper motor ($15)
Washer reservoir and pump ($5)
Drivers side vent window ($15)
Rear windows and seals ($25 both)
Rear, side marker lights ($5)
Headlights ($5 both)
Horn ($5)
I need to get all this stuff out of my barn, so prices can be flexible.  I have some more odds and ends so if you dont see something list, ask me, I might have it.
Reply #1March 26, 2009, 06:58:42 pm
Jolly1977
  • 43
« Reply #1 on: March 26, 2009, 06:58:42 pm »
Here's a link to photos of all the parts and shell.
http://s596.photobucket.com/albums/tt43/johndeere772002/
