Author Topic: rpm calculation  (Read 3045 times)
March 26, 2009, 10:43:56 am
allsierra123
rpm calculation
« on: March 26, 2009, 10:43:56 am »
Ok I ran all the numbers with the tires I have and my transmission it says I will be doing from 55-57 MPH at 3000 RPM.
My engine is an AAZ that is intercooled and I have a large oil cooler with a fan .
Will this rpm range be ok for the AAZ engine or do I need to work on lowering it more.
Reply #1March 26, 2009, 10:52:53 am
flapjack
  • 283
Re: rpm calculation
« Reply #1 on: March 26, 2009, 10:52:53 am »
Is that fast enough for highway cruising where you're at?
Going less than 60-65 round here is scary.
signature
Reply #2March 26, 2009, 12:17:45 pm
Re: rpm calculation
« Reply #2 on: March 26, 2009, 12:17:45 pm »
Quote from: "allsierra123"
the lower you the RPMs the better IMO, down to about 1800 or so.
Reply #3March 26, 2009, 12:55:38 pm
allsierra123
rpm calculation
« Reply #3 on: March 26, 2009, 12:55:38 pm »
Wa state Mostly for the entire state the speed limit is 60 or 65. Except for I90 where it is 70. I cruise between 60-65 everywhere I go. If I were living back in cali I may consider that dangerous. But here its kind of the flow of things.
Reply #4March 26, 2009, 02:16:52 pm
rpm calculation
« Reply #4 on: March 26, 2009, 02:16:52 pm »
a guy i know with a tdi in his westfalia had his transmission regeared
Reply #5March 26, 2009, 03:09:17 pm
rpm calculation
« Reply #5 on: March 26, 2009, 03:09:17 pm »
Quote from: "Trev0rbr"
that is an option, but a very expensive option if you don't do it yourself.  5th gear swaps are a good idea, but if you can find a TDI box for relatively cheap, then go with that.  tall 5th gears are usually hard to find, and aren't really cheap.
Reply #6March 26, 2009, 07:39:19 pm
Re: rpm calculation
« Reply #6 on: March 26, 2009, 07:39:19 pm »
Quote from: "jtanguay"
This is true the lower the better, but that doesnt mean you can't go higher! lol These engines are not weak, it will handle being run at 3000 without a problem. Its the same long term effect for any engine, gas or diesel. Running high RPM's constantly will take out your rings and cause you bad mileage.
Other than the mileage you should be ok :) you might want to look in to a 5th gear swap as stated earlier :)
hope it works out
Reply #7March 27, 2009, 12:00:02 am
allsierra123
rpm calculation
« Reply #7 on: March 27, 2009, 12:00:02 am »
Im running an auto box so its a little more to it than a regear. Just going to stuff as big of rubber under there as I can fit.
Reply #8March 27, 2009, 10:55:24 am
rpm calculation
« Reply #8 on: March 27, 2009, 10:55:24 am »
The Anti-Christ.. lmao
I see, so what about getting a diff trans? say maybe a 5-speed? lol
Reply #9March 27, 2009, 12:23:00 pm
rpm calculation
« Reply #9 on: March 27, 2009, 12:23:00 pm »
Thats what I would do as well.
Auto's rock as far as I'm concerned...
Reply #10March 27, 2009, 03:38:20 pm
allsierra123
rpm calculation
« Reply #10 on: March 27, 2009, 03:38:20 pm »
eventually I may. I just need to get it reliable first. Im into this conversion many a thousand so far. So I need to find a cheaper solution than gearing or a transmission conversion
Reply #11March 27, 2009, 04:24:37 pm
rpm calculation
« Reply #11 on: March 27, 2009, 04:24:37 pm »
Quote from: "zukgod1"
one of my goals in life is to take a vw diesel autobox, and CNC some super tall gears for it, and then test it out with a torquey 1.9TDI  :twisted:
i doubt it would last too long... it would almost require some motor oil or something thick with a huuuuge tranny cooler  :lol: cryo treated pretty much everything in there too!  i always have to link to this video when talking about auto's  :lol:
