Author Topic: WTB: Mk4 adjustable IP sprocket/hub asm.  (Read 3301 times)
March 24, 2009, 07:02:21 pm
autoholic
« on: March 24, 2009, 07:02:21 pm »
searching for complete MK4 adjustable IP pully/hub setup so that I can install a 20MM (shortshaft) IDI IP on my 1.6TD. Apparently this is the only practical option for my situation, I was not aware that the IP I bought was a "short shaft"
Cursed again!
~Mark
Reply #1March 24, 2009, 10:34:29 pm
svenson
  • 6
Re: WTB: Mk4 adjustable IP sprocket/hub asm.
« Reply #1 on: March 24, 2009, 10:34:29 pm »
Quote from: "autoholic"
Cursed again!
~Mark
you can also have the 1.6 pulley machined to fit the 20mm shaft
Reply #2March 25, 2009, 06:14:21 am
autoholic
« Reply #2 on: March 25, 2009, 06:14:21 am »
Thanks, yeah I am considering doing this, but re-creating that taper to fit at the right depth sounds tricky. I should bring a 17MM pump to the machine shop with the 2oMM so maybe it will be easier to match it up the depth?  The MK4 pulley set up still requires machining, but does not involve the taper, still has its own complications in that it has no key though, intial timing could be a pita.
Not sure what I'll do yet, just trying to avoid having a brand new Bosch paper weight!
Reply #3March 25, 2009, 06:40:31 am
Hey
  • 339
« Reply #3 on: March 25, 2009, 06:40:31 am »
Don't make it taper... have it make like the early AAZ pump... with a "pin"
Reply #4March 25, 2009, 06:46:05 am
svenson
  • 6
« Reply #4 on: March 25, 2009, 06:46:05 am »
Quote from: "Hey"
I dont understand this statement. ALL VE pump shafts all tapered, so it would have to be a tapered hole. I've machined more than ten 1.6 pulleys this way, and cut new keyway slots accurately.
Reply #5March 25, 2009, 06:59:22 am
autoholic
« Reply #5 on: March 25, 2009, 06:59:22 am »
Interested in doing another one Svenson? Maybe you even have a good 1.6 pulley there already? name your price! (wishful thinking I know, worth a try though)
Thanks.
