Author Topic: Pic request (no fun content)  (Read 5305 times)
March 24, 2009, 01:22:28 pm
spencebm
  • 686
« on: March 24, 2009, 01:22:28 pm »
I need a picture(s) of where the AAZ pump attaches to the bracket so I can see how the pump timing is adjusted once you have the pump attached.  Thanks guys.
Ben
Ben Spencer
Reply #1March 24, 2009, 02:12:18 pm
« Reply #1 on: March 24, 2009, 02:12:18 pm »
Reply #2March 24, 2009, 03:44:36 pm
spencebm
  • 686
« Reply #2 on: March 24, 2009, 03:44:36 pm »
thanks tyler but i am confused.  I had a pump that had the holes to move the pump around to adjust it but the 1.9 pump i have has thread only holes.  (no adjustment for timing)  is there a different bracket i need or is the sprocket on the AAZ engines where the adjustment takes place?  I went to switch pumps today and ran into this problem.  Plus i have never seen a real AAZ engine before so I can't tell what i need to swap.  I know you have the answers for me!  I will call Giles and ask him as well tomorrow.  Thanks again.
Ben Spencer
Reply #3March 25, 2009, 09:54:32 am
« Reply #3 on: March 25, 2009, 09:54:32 am »
We set the timing in the shop. It's preset to somewhere around 0.90-0.95. It always varies a bit. That black hub on yours, you put a 6mm (maybe 7) rod, drill bit etc into it and it slides into the housing of the pump right at the top behind the pulley.
The pulley that you are missing has the slotted bolt holes to allow you to lock everything up
