can any1 elplain how to swap pump tops?? AAZ top onto ABL pu
Topic: can any1 elplain how to swap pump tops?? AAZ top onto ABL pu (Read 3464 times)
March 22, 2009, 02:22:08 pm
rixy
March 22, 2009, 02:22:08 pm »
hi peeps, i wanna fit the pump top from my AAZ pump , onto the bottom end of my ABL ip. I know it can be done, just wondered if any1 can give me some rough instructions.
I will be removing the pump to do the modification, along with doing the gov mod at the same time.
Any help at all appreciated, cheers
GTD Caddy Soon..........
March 22, 2009, 02:36:55 pm
ryanp
March 22, 2009, 02:36:55 pm »
I need to know too, I'm fitting an AAz pump top to a 1y diesel pump to save breaking anthing, I'm a bit clumsy at times!
Ryan
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
March 22, 2009, 02:44:40 pm
MJF
March 22, 2009, 02:44:40 pm »
To both of you: chance the whole pump. 1Y and ABL have small 8mm pumps.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
March 22, 2009, 02:45:59 pm
rixy
March 22, 2009, 02:45:59 pm »
i cant change the pump, as the AAZ pump i've got is a lter spec electronic one, with sensors and extra bits all over it....so its no use to me other than the top??
March 24, 2009, 11:02:23 am
rixy
March 24, 2009, 11:02:23 am »
surely some1 has some idea on how to do it?? people all tell me it can be done, but no1 seems to wanna help???
March 24, 2009, 11:18:38 am
ryanp
March 24, 2009, 11:18:38 am »
I'm in the same boat now! just looked under the grime on the pump i got yesterday and it has the electronics too!
Damn!!
March 24, 2009, 12:02:23 pm
rixy
March 24, 2009, 12:02:23 pm »
can you explain what you mean by measuring the protrusion of the governor shaft?
can i do all of this with basic tooling etc? or is there anything specific i'd need? Circlip pliers etc??
Do you have any photo's you could circle, and label for me??
Should i do gov mod at same time? or just change pump top, get it running again, then do gov mod later, so sticking to changing one variable at a time??
Also, any step by steps on removing the pump??
March 24, 2009, 01:37:24 pm
rixy
March 24, 2009, 01:37:24 pm »
For plugging the hole you could use a ball bearing of a slightly larger diameter than the hole and then peen the case to hold it in??
what does peen mean??
the timing belt etc is allready brand new (1 week ago) so wont need to replace that, ha ha!!
Also, u mention the pic (stolen pic) with the governor shaft etc, but there is no pic attatched?? did u forget to post it, lol?
sorry for all the questions.......just gotta find my last post now, and find the pics u done for me before :-)[/code]
March 24, 2009, 02:15:10 pm
rixy
March 24, 2009, 02:15:10 pm »
also.......just another quick question.......will my "non turbo" pump be the same as that from a 1989 1.6 D?
Could i fit a 1.6 pump to my engine?? As if so, i'll just chuck a GTD pump straight on my 1.9? will this work??
Might be an easier way out maybe??
If not, i need a 1.9 pump, so i can build one, and keep my standard one standard (incase i mess it up - i dont trust myself)
grrrr.......dunno what to do :-(
March 25, 2009, 12:17:40 am
rixy
March 25, 2009, 12:17:40 am »
awesome, i now know what u mean by peening......it makes sense....cheers m8.
So are all the internals the same from the 1.6 to the 1.9? The dont run anything smaller internally etc, due to being for a 1.6, and not a 1.9?
if this is the case, then i'll just whack that on instead.
I do have the pulley from the 1.6, its still on the pump, only other thing is.....dont you set static timing by adjusting the pulley on a 1.9 pump, and its set by rocking the pump on a 1.6? will this still be the same?
March 25, 2009, 08:42:59 am
rixy
March 25, 2009, 08:42:59 am »
ok, no problems......
