Author Topic: Hey all - 1979 Rabbit Diesel - I'm prolly in over my head.  (Read 9290 times)
March 21, 2009, 04:43:53 pm
aphexjesus
« on: March 21, 2009, 04:43:53 pm »
Hey all. This is my first post here, although im pretty active in other forums, namely audiworld.com and s4forum.com (both as afxjzs).
I recently acquired a 1979 rabbit diesel from a friend that was moving and couldn't keep it. It's in pretty rough shape (rust is a factor), and needs some work, but seemed like it would be a fun 2nd car to work on. It is very yellow.
I live in Dorchester (part of Boston), MA and work for a large chain of autodealerships doing web design and other nerd stuff.
My main ride is a 2001.5 Audi S4 and the Rabbit is going to be a project car of   sorts. I plan on eventually converting it into a greaser, but for now, i just want to get it drivable.
Current (known) Issues:
 - The fuel line was cracked when the car got jacked up, so i replaced it with a new line, which seems to work, but now i need to bleed the fuel system (i think) to get it to run.
 - The coolant reservoir was completely empty with about a 1/2 inch of sludge in the bottom.
 - The brakes have a leak....somewhere. the reservoir was bone dry. I top it off and i could hear a distinct sucking and squirt sound near the front right when i pumped the brake.
Those are the main engine engine related ones. It has the rear suspension of a Fox (according to the guy i got it from) so it sits at top lock even with stuff in the trunk.
Here are some photos:
http://afx.cc/gallery/main.php?cmd=image&var1=My+Other+Car%2Frabbit+009.JPG&var2=700_85_copyright.png_RD
http://afx.cc/gallery/main.php?cmd=image&var1=My+Other+Car%2FIMG_0287.JPG&var2=700_85_copyright.png_RD
http://afx.cc/gallery/main.php?cmd=image&var1=My+Other+Car%2FIMG_0286.JPG&var2=700_85_copyright.png_RD
And 2 vids:
YouTube - 1979 Rabbit Diesel Engine Bay
YouTube - Rabbit Revs
(that's me in the car)
One more thing...
What the hell is this?
http://afx.cc/gallery/main.php?cmd=image&var1=My+Other+Car%2Frabbit+013.JPG&var2=700_85_copyright.png_RD
It wasn't connected to anything... It comes from the pass. side firewall.
Anyways... that's my situation. thanks in advance for all the help.
Reply #1March 21, 2009, 05:08:31 pm
Dakotakid
  • 1240
« Reply #1 on: March 21, 2009, 05:08:31 pm »
Nuclear material transport tube..........
No, an old air conditioner line.
Reply #2March 21, 2009, 05:36:04 pm
aphexjesus
« Reply #2 on: March 21, 2009, 05:36:04 pm »
Nice. Thanks. I can't believe this thing had A/C. Oh well...maybe it will again someday.
Reply #3March 21, 2009, 07:43:42 pm
« Reply #3 on: March 21, 2009, 07:43:42 pm »
Quote from: "aphexjesus"
with the hose being open like that, you can expect a lot of replacement parts to get it going again  :( a new receiver drier, and possibly a new compressor, and any lines that have been eaten through by the corrosive a/c oils.
Reply #4March 22, 2009, 08:56:49 am
aphexjesus
« Reply #4 on: March 22, 2009, 08:56:49 am »
yeah...that's way way way down the road. i am just trying to get the thing "drivable" and then maybe even someday "pass inspection"
for today, i'd like to see if i can figure out where the brakes are leaking from. I can hear a squirting sound when i push down the brake pedal, which can't be good.
Reply #5March 22, 2009, 11:21:24 am
Turbinepowered
  • 1206
« Reply #5 on: March 22, 2009, 11:21:24 am »
If you can't see any puddles under the car's corners, it might be a blown seal inside your master cylinder. All the leaking and squirting would be internal, so you wouldn't see a leak.
Reply #6March 22, 2009, 03:51:26 pm
aphexjesus
« Reply #6 on: March 22, 2009, 03:51:26 pm »
It's a broken brake line. I think there's a leak in the door and that submerged the brake line that runs inside the car along the floorpan. the one on the passenger side is leaking where it makes the 90deg turn to go towards the rear brake.
What's the procedure to replace a section of hard brake line? i imagine i'd need to get some sort of kit and maybe a tool or two.
the fuel line replacement worked. the car is running now, albeit a bit rough. the coolant reservoir was empty, so i filled that and ran the engine til it was warm, then changed the oil. starts up and idles just fine. it will be "drivable" once i get the brakes working.
anyone know how to get the carpet out?
I added some more pics to the gallery http://afx.cc/gallery/main.php?cmd=album&var1=My+Other+Car/
how come none of the pics i post are showing up? i have bbcode and html enabled and neither work. thanks.
Reply #7March 22, 2009, 04:17:09 pm
« Reply #7 on: March 22, 2009, 04:17:09 pm »
http://www.vwdiesel.net/phpBB/viewtopic.php?t=13132
as found in the FAQ. :wink:
Reply #8March 22, 2009, 06:24:45 pm
« Reply #8 on: March 22, 2009, 06:24:45 pm »
I use www.photobucket.com they have a link under each picture you upload for each of the several possibilities, like forum, email, webpage all that good stuff :)
Plus they automatically re-size each picture :)
Reply #9March 26, 2009, 06:44:43 pm
aphexjesus
« Reply #9 on: March 26, 2009, 06:44:43 pm »
Thanks for the tips. I actually tried both of those... no luck.
I started using Tumblr to post all the content for this project. Check it out at http://afxrabbit.tumblr.com
Reply #10March 26, 2009, 07:21:35 pm
« Reply #10 on: March 26, 2009, 07:21:35 pm »
Get to work! I want to see you finish this little guy up real good! :)
Keep us posted! :P
Reply #11March 27, 2009, 08:34:43 am
« Reply #11 on: March 27, 2009, 08:34:43 am »
That's too cool man..
Welcome to the board, we are all connected it seems. My "Other" car is an 02 Passat 1.8t (not stock). zukgod1 on the tex as well.
That engine sounds really good! You got your self a builder for sure.
There is tons of info here and you will soon see this place is NOTHING like the tex. Bashing is all but non exsistant, help is abundant. Usualy if there is a smart a$$ comment it comes from me  :? .
Reply #12March 27, 2009, 08:35:33 am
« Reply #12 on: March 27, 2009, 08:35:33 am »
Got any pics of your S4?
Reply #13March 29, 2009, 07:35:29 am
drrtybyl
  • 146
bizarre..
« Reply #13 on: March 29, 2009, 07:35:29 am »
I just looked at your photo gallery -- my '79 came with bullets too..  not sure what it is about old rabbits that they end up with ammo inside.
'79 Rabbit Diesel L
'94 Chevy 2500 6.5TD
'96 BMW 318ti
Reply #14April 11, 2009, 01:24:36 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
« Reply #14 on: April 11, 2009, 01:24:36 pm »
I took the trunk mat out last night and I found I bet 300 or more 22 bullets and more assorted ammunition in mein jetta
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
