Author Topic: Where does Glow Plug power start from??(No power at all)  (Read 4001 times)
March 20, 2009, 11:10:14 pm
AudiVWguy
« on: March 20, 2009, 11:10:14 pm »
81 Caddy, MK1. It was getting hard to start, the reason was no power at the G-plugs, fuse is good, back to the relay, test light shows no power. Where does the wire from the relay start from?  I guess I need to trace it back from the beginning.
Thanks!!
Reply #1March 21, 2009, 05:14:50 am
« Reply #1 on: March 21, 2009, 05:14:50 am »
So you checked for power at the 2 large spade terminals where the GP relay plugs into and there was nothing? What were you grounding to?
If that's the case, drop the fuse panel and you should see a large red wire (maybe red/black, I don't have my bentley ATM) coming from the back of the GP relay. Follow that one.
Reply #2March 22, 2009, 07:21:56 pm
AudiVWguy
« Reply #2 on: March 22, 2009, 07:21:56 pm »
I followed it back to where it was connected. At the bolt on the starter. The connection had a couple of iffy splices in there. Cut out the splices and gave it it's own dedicated cable. :twisted:  They function correctly now.
The starter still turns slower than it should. :x
Thanks
Reply #3March 23, 2009, 04:50:54 am
« Reply #3 on: March 23, 2009, 04:50:54 am »
Do a voltage drop test on the wires going to and from the starter
Reply #4March 25, 2009, 09:21:33 pm
AudiVWguy
« Reply #4 on: March 25, 2009, 09:21:33 pm »
I had an extra starter, installed it. That was the problem, starts way better now.
