Author Topic: cut off solenoide (Ip)  (Read 3531 times)
March 17, 2009, 01:12:38 pm
jbturgeon
  • 71
« on: March 17, 2009, 01:12:38 pm »
Hi, I am installing my injectors and stars bleeding them. I am not sure why there is no spray coming out of the ip but the gas is circulating trought the pump as i got gas coming out of the soft bleeding line when unplugged.
Any issue?
Thx
AAZ for life!
Subaru Loyale 4x4
Reply #1March 17, 2009, 02:09:06 pm
rallydiesel
  • 1880
« Reply #1 on: March 17, 2009, 02:09:06 pm »
I would keep cranking it for a while. It takes a good couple minutes (cumulative, not all at once!) before you get most of the air out. If the injector return lines are flowing diesel then it's unlikely to be the solenoid, although you can quickly check to see it's getting power with a voltmeter.
I would say you still have air in the injector hard lines preventing you from reaching injector opening pressure.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2March 17, 2009, 03:36:26 pm
jbturgeon
  • 71
« Reply #2 on: March 17, 2009, 03:36:26 pm »
Thx rallye, everything is fine since i put my negative pole back as well as the key on. Works well now!
AAZ for life!
Subaru Loyale 4x4
