Author Topic: GT18V Turbo charger, 200hp++ VNT15 spool!  (Read 5556 times)
March 14, 2009, 03:59:30 pm
ryanp
  • 269
« on: March 14, 2009, 03:59:30 pm »
the wheels are massive! These are reported to spool like a standard ALH VNT15 turbo but boost more like a VNT20, the best of both worlds! I was going to use it as it would be future proof as the lag would be non existant on a reserved tune but pack a punch if i fitted bigger injectors!
It has the same flanges as the 1749VA units from a passat (separate manifold design) so should bolt up nicely with a passat manifold or a tubular/cast item from Kerma ect.
The centre section is also separate from the turbine and compressor housings so can be re-clocked to fit any situation!
$400 + shipping. I can send this anywhere in the world via tracked and insured mail!
If anyone has any problems with me being new ask around on TDi club, I've sold a few turbos, PD150 injectors and some other stuff without any problems.
Thanks
Ryan
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #1March 14, 2009, 05:02:45 pm
rallydiesel
  • 1880
« Reply #1 on: March 14, 2009, 05:02:45 pm »
Where are you at?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2March 14, 2009, 08:57:16 pm
subsonic
  • 1836
« Reply #2 on: March 14, 2009, 08:57:16 pm »
Quote from: "rallydiesel"
Where are you at?
Hint:
God save the queen, Union jack and all that.
Throw in your location Ryan.
Reply #3March 15, 2009, 04:53:50 am
ryanp
  • 269
« Reply #3 on: March 15, 2009, 04:53:50 am »
Im in the UK, the flange may well be rotated 180degees, ive had a 1749va but i never had them side by side.
I'm not using it because it wont fit with my manifld plans and i dont want to go to the hassle of a VNT linkage, at least not yet!
I've updated my profile with my location, i though i already had!
Reply #4March 15, 2009, 10:48:54 am
aidan
« Reply #4 on: March 15, 2009, 10:48:54 am »
The Passat manifold does have a slightly rotated flange to match this, but the AHU/1Z has the same flange without the rotation.
This is not to say it'll definitely work, but an option to consider
