Author Topic: Coolant T at the head thing  (Read 3636 times)
March 13, 2009, 04:36:52 pm
  • 3468
    • McScrubbins Body Wash
« on: March 13, 2009, 04:36:52 pm »
The T with the two sensors in it that feed the top of the Rad and join to the water pump.
How do you get that thing to seal without stripping the threads in the head? Either it's leaking from the sensor or that T at the head.
I think the rubber ring might be too large or something?
anyone ever helicoiled the block to finally get that sucker on there tight?
Reply #1March 13, 2009, 04:48:04 pm
« Reply #1 on: March 13, 2009, 04:48:04 pm »
Looking at the head in the car, the thing on the right? I have never had a problem. I would either by a new gasket or make one. If you make one I have had some luck with the cardboard on beer cases cut to shape or silicone. shouldn't be that hard to seal. Take a look and see if it is warped when you take it off.
Reply #2March 13, 2009, 04:52:58 pm
  • 1739
« Reply #2 on: March 13, 2009, 04:52:58 pm »
Those plastic flanges warp with the heat over time. Overtightening them also warps them. Buy a new one and while it's off, check the surface where the seal sits. It may be corroded. If so clean and dry the surface and fill it with JB weld or some other kind of good epoxy, sand flat . If the threads are stripped, helicoil it.
Reply #3March 13, 2009, 04:58:31 pm
Rabbit TD
  • 840
« Reply #3 on: March 13, 2009, 04:58:31 pm »
Quote from: "theman53"
Yeah I've had to make a lot of gaskets since I got into this thing too.  I found that Autozone has regular gasket material in small rolls of different thicknesses and Tractor Supply had a nice little punch kit back in the leather section for saddles and stuff for just a couple dollars.  A punch makes it a whole lot easier and that is where you usualy mess up a home made gasket.
Reply #4March 13, 2009, 05:01:38 pm
  • 3468
« Reply #4 on: March 13, 2009, 05:01:38 pm »
Home made gaskets is a good idea.
I made one out of a washer for the oil temp sender that kept leaking.
It's a brand new head so i think the plastic thing is warped. Thanks!
Reply #5March 13, 2009, 05:07:20 pm
« Reply #5 on: March 13, 2009, 05:07:20 pm »
- they warp all the time
- they're dirt cheap... get a new one *and* a new o-ring
- tightening them down more won't help.. and in fact makes them warp more
- make sure the sealing surface (the block) is flat/lapped
Reply #6March 13, 2009, 05:58:06 pm
« Reply #6 on: March 13, 2009, 05:58:06 pm »
i bet you could sand the plastic flange flat the same way you'd lap the injectors. use 1200 grit sandpaper to make it real nice and shiney.  if its super warped then you'll need a new one, unless you want to remove some material for the o-ring.
Reply #7March 13, 2009, 07:22:37 pm
« Reply #7 on: March 13, 2009, 07:22:37 pm »
I didn't even realize that it is plastic and had the oring until I went downstairs and looked at mine which I thought for sure is a cast of some kind. Maybe the 1.6 is different than yours. If you have access to a belt sander you could get it real close to flat. Then use whatever to smooth it up. Since it has the oring and not a gasket you might not need to get it like glass. Silicone can be your friend sometimes. I have had amazing luck with a permatex "Right Stuff" and a Ford grey colored stuff that you can only get at the stealerships. They are like an adhesive and a gasket.
Reply #8March 14, 2009, 12:24:17 am
  • 3468
« Reply #8 on: March 14, 2009, 12:24:17 am »
-dirt cheap from where?
- augh so frustrating. That means dumping the coolant which wouldn't be such a big deal if i could find a clean bucket
Reply #9March 14, 2009, 08:29:44 am
rallydiesel
  • 1880
« Reply #9 on: March 14, 2009, 08:29:44 am »
Yeah, where do you get it? I have never been able to find the two sensor flange anywhere. The single sensor flange is easy to get but not the two sensor flange.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #10March 14, 2009, 10:58:45 am
sdwarf36
  • 159
« Reply #10 on: March 14, 2009, 10:58:45 am »
That was the 1st part I had to buy when i got my Jetta. I found this place thru ebay. Turned into one of my favorite places to get vw parts. Been in the VW biz since flower power days. Knowledgable and a darn nice guy to boot.
pelhamauto.com
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #11March 14, 2009, 11:49:49 am
« Reply #11 on: March 14, 2009, 11:49:49 am »
Assuming I'm thinking what you're thinking (a leap of faith right there!) its a 037-121-144H and it's about 8 CDN bucks from the Worldpac-type suppliers.
Unfortunately that link doesn't have a picture... but if you google that part number you might be able to find a reference somewhere to see if we're both talking about the same thing.
Reply #12March 15, 2009, 10:05:56 pm
  • 3468
« Reply #12 on: March 15, 2009, 10:05:56 pm »
Yeah i like that site vince. But they really get ya on shipping. So you have to wait till you have a big order before it's worth it.
Reply #13March 15, 2009, 10:51:18 pm
cyrus #1
  • 360
« Reply #13 on: March 15, 2009, 10:51:18 pm »
AVR will have them for sure.  They weren't huge money the last time that I bought them.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #14March 16, 2009, 03:21:48 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #14 on: March 16, 2009, 03:21:48 am »
037-121-144H picture
Calvin
91 VW Golf 1.6NA 5spd
