Author Topic: how do i change pump tops?  (Read 4457 times)
March 11, 2009, 11:55:15 am
rixy
  • 70
    • http://www.ec-dc.co.uk
« on: March 11, 2009, 11:55:15 am »
hi peeps, i have a IP from my ALB t4 engine, with no boost enrichment on it, and i also have an AAZ pump, with LDA etc all on the top.
Basically,i wanna fit the top of the AAZ pump onto the ALB one, as i'll be removing the top anyway, to have a got at the gov mod.
Can the tops be swapped, and how is it done??
Any how to's??
Or should i just fit the AAZ pump and leave it as is?? Only prob i can see is my immobiliser, can these be swapped from pump to pump?
GTD Caddy Soon..........
Reply #1March 11, 2009, 04:08:34 pm
« Reply #1 on: March 11, 2009, 04:08:34 pm »
If the immobilizer you are talking about is the black box over the stop solenoid, just run 12v to the new stop solenoid from a switch. If you are going to splice it into a wire in the engine bay, make sure that that wire has power when you are cranking.
